Garmin GLO
red_nose
red_nose
Too Much Forum (933 reputation)Too Much Forum (933 reputation)Too Much Forum (933 reputation)Too Much Forum (933 reputation)Too Much Forum (933 reputation)Too Much Forum (933 reputation)Too Much Forum (933 reputation)Too Much Forum (933 reputation)Too Much Forum (933 reputation)
Posts: 6, Visits: 32
I hesitate to buy either a Garmin Glo aviation or a Bad Elf pro (which don't work with Android it seems but with a tracking function)
Please your opinion
Happy new year
Red Nose
http://LF5422.wordpress.com
red_nose
LF5422@gmail.com
Runways
Runways
Posts: 309, Visits: 1.6K
Just a little note that came to my attention after I purchased Garmin GLO.
Looking at the Specs of the later models of iPAD & iPAD mini as advertised by Apple company (after my purchasing event Blush!) I note a referance to their internal GPS being able to receive GPS + GLONASS , denovo. This means that GLO may not be a necessary addition afterall. That is other than using GLO as a convenient well placed wireless & out of the way, remote antenna.
As far as Bad Elf, It seems to support :
1. EGNOS (Western European),
2. MSAS (Japan and East Asia) &
3. WAAS (North America).
...But Bad Elf does not utilise GLOSNASS
I am not too sure of the significance or impact of that on using Bad Elf versus Garmin Glo in air navigation in the UK or Europe. The European more sophisticated Galileo is not operational yet.
Any one with a different view/experience/suggestion is welcome to comment.
Very Newbytheway
DurhamTeaseAirport
Edited 1/3/2013 10:54:38 AM by Runways
NeilP
N
Too Much Forum (840 reputation)Too Much Forum (840 reputation)Too Much Forum (840 reputation)Too Much Forum (840 reputation)Too Much Forum (840 reputation)Too Much Forum (840 reputation)Too Much Forum (840 reputation)Too Much Forum (840 reputation)Too Much Forum (840 reputation)
Posts: 9, Visits: 0
So if you can use the GLO, which I have just updated to Glo firmware version 2.90. ..how do you do this?
‌I have the iPAD Pro and SD 3.7.1.61
‌But I do not see the Glo listed under the Connectivity options
‌The GLO is connected to the iPad via BT and it shows a solid blue light and is on the iPad BT connected device list. but it does not show ups in Sky Demon.
‌How do you make it connect  ‌to Sky Demon once it is connected to the iPad ?
Edited 3/23/2017 6:22:30 PM by NeilP
Just press Go Flying and use Location Services. Your GLO will be feeding location services.
NeilP
N
Posts: 9, Visits: 0
Tim Dawson - 3/27/2017 3:32:38 PM
OK< thanks , just wondered if I could be sure it was using the GLO and not the iPad GPS
‌Thanks
Unfortunately not - iOS doesn't give any mechanism for achieving that.
NeilP
N
Posts: 9, Visits: 0
Tim Dawson - 3/29/2017 1:20:39 PM
OK
Rolandasa
R
Too Much Forum (107 reputation)Too Much Forum (107 reputation)Too Much Forum (107 reputation)Too Much Forum (107 reputation)Too Much Forum (107 reputation)Too Much Forum (107 reputation)Too Much Forum (107 reputation)Too Much Forum (107 reputation)Too Much Forum (107 reputation)
Posts: 1, Visits: 0
Anyone know how to make sure or check if the GLO is actually feeding the Skydemon, but not the default ipad GPS?
Thomas Leaver
Thomas Leaver
Too Much Forum (704 reputation)Too Much Forum (704 reputation)Too Much Forum (704 reputation)Too Much Forum (704 reputation)Too Much Forum (704 reputation)Too Much Forum (704 reputation)Too Much Forum (704 reputation)Too Much Forum (704 reputation)Too Much Forum (704 reputation)
Posts: 9, Visits: 0
It will say gps signal lost if it is not functioning.
davidpettersson
d
Too Much Forum (123 reputation)Too Much Forum (123 reputation)Too Much Forum (123 reputation)Too Much Forum (123 reputation)Too Much Forum (123 reputation)Too Much Forum (123 reputation)Too Much Forum (123 reputation)Too Much Forum (123 reputation)Too Much Forum (123 reputation)
Posts: 1, Visits: 0
Does anyone have any data on the altitude accuracy? I am currently using a Lenovo Android tab with Skydemon, and while the relative height is decent using only the builtin GPS, I typically see some pretty bad offsets where the GPS tracks state that I land underground or mid air. :-)
I‌ seem to find any details on altitude accuracy in any spec sheet. :-(
T‌‌hanks!
