Poland
sochasz
sochasz
Posts: 16, Visits: 73
Radio for example EPMO in SkyDemon is 123.920 should be 123.925 and this mistake is in other arfields radios (EPGY)
In older version was ok, now changed and it's wrong.
VFR in Poland is in class G, I can't see class G in SkyDemon.
Thanks, I can see the frequency issue and we will fix this in the next chart update. It's just that the trailing 5 which of course should be present on such frequencies has been truncated, so hopefully it is obvious which ones need the 5 adding back.
We do not depict class G airspace explicitly in SkyDemon; all areas which are not controlled airspace are assumed to be class G.
sochasz
sochasz
Hi. thanks for answer and promise that you will fix it.
But you're right that is obvious that 5 is truncate when end of frequency is 000.()20, only found mistakes with this end of frequency.
But we both agree that in aviation information should be ok. It's for safety of course.
Again thanks for decision to make Ipad version.
Best regards.
sochasz
sochasz
"[quote]Tim Dawson (15/02/2012)
Thanks, I can see the frequency issue and we will fix this in the next chart update. It's just that the trailing 5 which of course should be present on such frequencies has been truncated, so hopefully it is obvious which ones need the 5 adding back."
Now is everything ok!
Best Regards
Edited 3/15/2012 1:56:52 PM by sochasz
sochasz
sochasz
I would like inform that now in Poland we can use military METARS.
Maybe SkyDemon will be use these information also for Poland.
best regards.
kostekxl
kostekxl
Too Much Forum (219 reputation)Too Much Forum (219 reputation)Too Much Forum (219 reputation)Too Much Forum (219 reputation)Too Much Forum (219 reputation)Too Much Forum (219 reputation)Too Much Forum (219 reputation)Too Much Forum (219 reputation)Too Much Forum (219 reputation)
Posts: 1, Visits: 6
Most Aeroklub and ULM strips In Poland are avaible to download from this page in garmin format .
sochasz
sochasz
Radio frequency in Jastarnia airfield EPJA is 120.025 (http://lotniska.dlapilota.pl/jastarnia) in SkyDemon is wrong 125.550. Please check it, thank you.
Thanks, I will forward this to my colleague. Please feel free to start a new thread for such feedback; this one was finished last year.
