Mag Track
neutron
neutron
Posts: 8, Visits: 15
I would guess that the answer to that question is yes. Certainly my aviation GPSs, both fitted and portable  use Mag as default.
Perhaps it would be useful to ask the question on the Flyer forum?
neutron
Are you saying that on all the handheld VFR GPS units that our customers are using, the track being displayed is magnetic and they are not just outputting the true track as received directly from the GPS chipset?
neutron
neutron
I think the problem is that when training for your PPL you are taught - draw the line on the chart (True Brg), apply wind correction (True Brg), apply mag variation/compass deviation to get Mag Heading and that's what you fly.
Once you start flying, all that goes out of the window and most pilots fly using some form of radio navigation, be that VORs, NDBs or most usually now GPS. For all of these the standard convention is to fly Mag not True so it's the Mag Track between beacons/waypoints that you need. We're lucky in the UK, our magnetic variation is in the low single digits, typically around 3-5 degrees so the difference between True and Mag is not that great. There are places where it's well over 30 degrees different and they still use Mag Tracks for Nav.
neutron
screetch82
screetch82
Posts: 123, Visits: 176
hi I agree that the Mag Track is important. Although you fly compass headings but in order to calculate those you need the magnetic headings first of all.
Thanks Neutron. Hopefully we'll get more input on this now there's a suitable thread for it.
neutron
neutron
OK
To reply to your questions:
> The reference instrument for all aircraft flying today is still the magnetic compass.
Yes. However once airborne the compass will not read the same as the potential mag track column unless there is nil crosswind. I'm afraid I therefore don't understand the relevancy of this statement.
The relevence of this is that all in-flight bearings should be derived from the same datum and magnetic is the one used universally. The CDIs on your nav instruments whether they be traditional steam VOR indicators or GPS driven CDIs need to be set to the MAGNETIC Track you intend to follow. The offset wind derived magnetic heading is the heading you fly to achieve the selected Magnetic Track
> It is the magnetic track ... that is entered into ... built-in IFR GPS's.
This is pretty compelling. When would you enter an actual track (whether it's true or magnetic) rather than simply entering the waypoints?
You would normally enter waypoints but you might well enter a magnetic track to fly on the HSI page of your GPS. Certainly your GPS should display the Magnetic Track to the next waypoint which should agree with the Magnetic track you have dialled into your CDI instruments.
> All runway headings are in degrees magnetic as are all bearings derived from VORs.
Yes, but it is unclear how having SkyDemon output legs as magnetic bearings is relevant to runway headings. Could you explain how bearings derived from VORs relate to one's PLOG, unless you are actually tracking along a radial?
It's not just bearings derived from VORs and you don't need to be tracking a VOR radial - any course you set in a CDI instrument needs to be set as a Magnetic Track. A CDI type panel mounted GPS Indicator as well as a VOR indicator (which may be operating in RNAV mode with a pseudo-VOR displaced onto the waypoint) needs to be set up with the Mag Track to the waypoint so you need that information on the PLOG.
> All bearings on airfield plates are in degrees magnetic.
Agreed. However the PLOG shows enroute legs only; could you explain how the potential mag track column will be used to relate to the magnetic bearings shown on airfield plates?
It doesn't but that's hardly the point. The real thrust of my argument is that you need to stick to one datum - magnetic.
Hope this helps.
neutron
Would you mind responding to the points I raised?
SkyDemon is software targetted at pilots who will be flying VFR and it sounds rather like the justifications you're using are based on navigation either with an IFR GPS or by tracking from VOR to VOR. This is of course perfectly valid, but the majority of our customers appear to navigate either with a VFR handheld GPS or with a VFR chart. Radio aids are often used of course, to confirm position, but do not necessarily comprise the route itself so having something to "dial in" to the HSI wouldn't be required.
Again, I stress that this is merely our experience of customer feedback and this is what drives which features make it into the product. Perhaps we'll get lots of (unsolicited) input in this thread from people who'd like to see an option for mag track added to the PLOG. In which case - we'll add it!
neutron
neutron
I sent you the pm. For some reason, the forum allows you to post pms without being logged in. The full text of my pm is below:
The reference instrument for all aircraft flying today is still the magnetic compass and therefor once you are in an aircraft all tracks, headings, brearings and vectors are given in degrees magnetic. It is the magnetic track not the true track that is entered into all the aircraft's navigation instruments including built-in IFR GPSs. All runway headings are in degrees magnetic as are all bearings derived from VORs. All bearings on airfield plates are in dregrees magnetic. It is the true track that is irrelevent!
How is SkyDemon applying magnetic variation, which varies from place to place? I have a suspicion that the derived mag headings which with zero wind should be the same as mag track are some degrees out for tracks in my local area.
My point is that at present, all headings, tracks, radials, intercepts and radio navigation is carried out in the aircraft using magnetic bearings hence the importance of including mag track in the PLOG. It is mag track you set in HSI or CDI. It is the mag track from waypoint to waypoint that is displayed on IFR GPS sets. True track is not used other than to plot one's course on a chart which is then converted to mag track for navigation purposes.
neutron
I received a PM from Anonymous with some points about magnetic track which, since the sender was Anonymous, I couldn't repond to so I'll do so on here. Please bear in mind I'm not trying to say that anyone is wrong, but trying to provoke significant justification such that we can make a case to change or enhance the software.
SkyDemon uses the standard magnetic model of the earth to calculate the exact magnetic declination at the midpoint of each leg, on the day the flight is planned. If you think SkyDemon's value for magnetic declination at a specific point is wrong, please let us know the position and what you think it should be.
I deleted your last post as it appeared only to call into question the aviation experience of the SkyDemon staff and not to contribute anything to this discussion.
Let me frame my last statement in the context of "for a piece of flight-planning software". The reason why pretty much every feature of SkyDemon is the way it is, is because of either customer feedback or prioritisation of features. So far we've had a grand total of one person ask for magnetic track to be displayed on the PLOG. There would be no surer way to ensure the eventual failure of the SkyDemon product than to implement every feature that every person asks for, so we operate based on consensus.
1. SkyDemon does not feature full vertical navigation facilities. This topic has been addressed elsewhere in this forum and the basic answer is "they will come when there is sufficient demand".
2. You are expected to work in TAS in SkyDemon; it's unclear what the "etc" in your point refers to. Again, we have a great deal of customers but none of them have so far expressed a desire to operate in IAS when planning a route.
3. If you believe some of the areas of Scotland in which we have designated FIS frequencies are incorrect, or the frequencies themselves are incorrect, tell us which ones and we will investigate. I do not recall receiving a report from you about this.
4. There is little we can do about this at this point in time.
5. Probably the coastline, which in some areas can be off by as much as 1nm but in most areas is accurate. Again, if you find that a town appears to have the incorrect coordinates, let us know about it.
Edited 7/20/2010 12:20:24 PM by Tim Dawson
