PA-28R-180 Arrow Profile
adhawkins
adhawkins
Posts: 274, Visits: 2.5K
Like I said, I already have a profile of sorts. It's rough and ready, but has the speeds and weight and balance information correct.
Climb, descent and fuel usage just needs setting up properly with reference to the (or even a) POH.
Andy
stevelup
stevelup
Group: Moderators
Posts: 593, Visits: 4.9K
Then between you, you've got no excuse for not creating a profile for it Laugh
adhawkins
adhawkins
I suspect the OP flies the same Arrow as I do Steve Smile
Andy
stevelup
stevelup
Group: Moderators
Hi folks,
It takes about ten minutes max to create an aircraft profile from your POH and it isn't difficult.
Bear in mind that the figures for the different variants will be... different - so if you want it to be right, you're best off doing it yourself! No harm in sharing it here when you've done though Smile
adhawkins
adhawkins
I've got one, but I don't know how accurate it is. The main thing I use the aircraft profiles for are cruise speed and weight and balance.
The climb / descent and fuel calculations are unlikely to be correct.
Andy
Colin Bond
Colin Bond
Posts: 63, Visits: 510
Mark, any joy yet?
Colin.
markpodbery
markpodbery
Posts: 10, Visits: 42
Hi all,
Looking for the above please??
Many thanks
Mark
