Aircraft Profiles
PA-28R-180 Arrow Profile
markpodbery
markpodbery
posted 9/20/2012 1:25:56 PM
Visits: 42
Hi all,
Looking for the above please??
Many thanks
Mark
Colin Bond
Colin Bond
posted 9/30/2012 7:00:16 AM
Visits: 510
Mark, any joy yet?
Colin.
adhawkins
adhawkins
posted 10/1/2012 12:45:14 PM
Visits: 2.5K
I've got one, but I don't know how accurate it is. The main thing I use the aircraft profiles for are cruise speed and weight and balance.
The climb / descent and fuel calculations are unlikely to be correct.
Andy
stevelup
stevelup
posted 10/1/2012 1:06:24 PM
Group: Moderators
Visits: 4.9K
Hi folks,
It takes about ten minutes max to create an aircraft profile from your POH and it isn't difficult.
Bear in mind that the figures for the different variants will be... different - so if you want it to be right, you're best off doing it yourself! No harm in sharing it here when you've done though
adhawkins
adhawkins
posted 10/2/2012 1:18:54 PM
Visits: 2.5K
I suspect the OP flies the same Arrow as I do Steve
Andy
stevelup
stevelup
posted 10/2/2012 9:36:42 PM
Group: Moderators
Visits: 4.9K
Then between you, you've got no excuse for not creating a profile for it
adhawkins
adhawkins
posted 10/3/2012 12:37:43 PM
Visits: 2.5K
Like I said, I already have a profile of sorts. It's rough and ready, but has the speeds and weight and balance information correct.
Climb, descent and fuel usage just needs setting up properly with reference to the (or even a) POH.
Andy
