Route line obscures map data
Alexey
Alexey
Posts: 20, Visits: 77
Hi Tim.
On MD Route line obscures map data, in particular Visual Reporting Points.
Small detail, but I find myself frustrated with it very often. Usually I can recognize VRP is there, but the letter is masked.
Is there a way to paint some map data, especially VRPs on top of route line?
Also when zoom in, route line proportionately increases to some unreasonably big width. If when zooming route line scale could remain (narrow) this might partially rectify above mentioned problem.
AlanM
AlanM
Posts: 31, Visits: 68
Alexey and Tim,
I am also having this problem and seem to remember making the same query on SD2.2.
Is it possible to make the route line thickness user selected?
Just had a 1500Nm tour taking in 5 counties all using SD on a 5" £35 off ebay Chinese car satnav. Only 2 problems, VRP waypoints are lat-long in filed flight plans and the cheap device did not like the heat when mounted in the windscreen causing the touch screen to stop working but the software was great.
AlanM
