Export to fsx (.pln)
pmb
pmb
Posts: 4, Visits: 24
I am new to this forum and not (yet) a customer. I am not a real world pilot, however a 20 yrs Flight Simulator pilot. SkyDemon has a very nice interface and might be well suited for flight simulation, too. Did you ever think about implementing an export module for MS Flight Simulator X (.pln) flight plans? I'd expect not all features of SkyDemon can be exported to proper variables of fsx, but basically this sound an interesting idea to me (and would make SkyDemon an interesting program for me, even more, as I mostly fly VFR.)
Kind Regards, Michael
pmb
pmb
Biggles-EGKB (14/08/2012)
SD does interface extremely well with FS and I have undertaken many a flight initially on the simulator under adverse weather conditions before going out and doing the flight for real.
Hope this helps.
Thank you. This is another kind of interaction than I had in mind, but it is sure interesting. Actually, I have a 2 PC setup with several add-ons running on a Laptop, however they're connected via a hard wired Ethernet router. Is there support for this, too?
Biggles-EGKB
Biggles-EGKB
Posts: 51, Visits: 417
The VSPE software works independently of the method of data transfer (wired or wireless). VSPE does what is says on the tin, it allows one device to "see" the data of another device as a COM PORT across a network.
Biggles -- EGKB
Edited 8/14/2012 11:00:47 PM by Biggles-EGKB
pmb
pmb
Thanks again - not sure if I'll be able to configure that beast, but I might try once I can allocate some spare time.
BTW, just for the record, the correct URL is http://www.eterlogic.com/Products.VSPE.html
Kind regards, Michael
Biggles-EGKB
Biggles-EGKB
It's not all that difficult but if you get stuck, put a post up and I'll outline the stages.
Biggles -- EGKB
Ivanr
Ivanr
Too Much Forum (263 reputation)Too Much Forum (263 reputation)Too Much Forum (263 reputation)Too Much Forum (263 reputation)Too Much Forum (263 reputation)Too Much Forum (263 reputation)Too Much Forum (263 reputation)Too Much Forum (263 reputation)Too Much Forum (263 reputation)
Group: Awaiting Activation
Posts: 1, Visits: 2
Back on topic
You could try this utility for converting gpx to pln files.
http://www.flightutilities.com/FP.aspx
pmb
pmb
Hi Ivanr,
this is indeed what I was looking for at first. I am just on a holiday trip without access to my flightsim PC but will try this out later.
Thank you very much,
Edited 8/19/2012 9:42:32 PM by pmb
pmb - 8/13/2012 9:09:54 PM
Biggles-EGKB - 8/14/2012 9:50:59 PM
pmb - 8/14/2012 10:03:41 PM
Biggles-EGKB - 8/14/2012 10:56:21 PM
pmb - 8/14/2012 11:17:16 PM
                         It's not all that difficult but if you get stuck, put a post up and...
Biggles-EGKB - 8/15/2012 12:15:30 AM
                             Back on topic You could try this utility for converting gpx to pln...
Ivanr - 8/17/2012 12:26:04 PM
                                 Hi Ivanr, this is indeed what I was looking for at first. I am just...
pmb - 8/17/2012 10:12:37 PM
SE-AKS - 8/18/2012 10:48:50 AM
