SkyDemon Navigation
Changing from Garmin 496?
VMC-on-top
VMC-on-top
posted 8/7/2012 4:16:13 PM
Visits: 62
HI all,
I've been using SD plan for a couple of years, think it is superb. However, I've stayed away from SD's own box for some time due to the robust nature of the 496. However, I think it is about time that I give it a try.
I'm assuming there will be plenty of folks on here who've used a 496 and switched to SD's own box? Can you tell me what, if any, features are on the 496 which aren't on the SD box? I'm thinking things like
1. "nearest [town / VRP / VOR / airfield]" at the touch of a button (with miles to each), for reporting position etc.
2. "dct to" - as previous, airfield, VRP etc. - are they features on SD too?
3. What is the battery life like compared to the 496?
4. Is it a touchscreen and if so, how easy is it to use / pan / zoom in and out etc.
5. Is there data available for sunrise and sunset times on the unit?
6. Am assuming data displayed on the "front" screen can be changed to show eta, ete, distance to next etc.?
7. Does the unit have a dimmer control?
8. Are previous flight plans stored in the unit?
9. Is there airfield information available for alternates? - assume a divert to somewhere, runway length, runway surface, frequencies etc.?
10. W&B calcs
11. Terrain warnings
Basic questions I know so apologies if this has been covered elsewhere.
thanks!
Edited
8/7/2012 4:20:14 PM by
VMC-on-top
pink leader
pink leader
posted 8/7/2012 8:10:05 PM
Visits: 2K
I will try to answer as best I can. I have both a 496 and a 7" WinCe device in the cockpit.
Your Qs were as below and I will insert my answers for each Q
1. "nearest [town / VRP / VOR / airfield]" at the touch of a button (with miles to each), for reporting position etc. Click on the plane and it give position report - on Ipad I think its permanently on the top line of the screen 2. "dct to" - as previous, airfield, VRP etc. - are they features on SD too? Double click SD icon and nearest airfields are shown - filtered to take account of your min runway length - with nearest first 3. What is the battery life like compared to the 496? WinCE devices generally have awful battery life (ipad is fine) - you either need secondary battery (easy) or better still cigarette lighter power 4. Is it a touchscreen and if so, how easy is it to use / pan / zoom in and out etc. Very easy - actually ipad is a bit too easy and you can inadvertently rubberband a leg 5. Is there data available for sunrise and sunset times on the unit? Not a feature I have needed to use - don't know 6. Am assuming data displayed on the "front" screen can be changed to show eta, ete, distance to next etc.? Correct 7. Does the unit have a dimmer control? Yes - but don't be fooled - WinCE units are typically not fully sunlight readable and few cheapo WinCE units have the same 400NIT brightness of the 496 and fewer still have the coating of the 496 that helps its readability in bright light 8. Are previous flight plans stored in the unit? Yes 9. Is there airfield information available for alternates? - assume a divert to somewhere, runway length, runway surface, frequencies etc.? Yes. Suggest you go into the simulation mode on your desktop. Latest plates from SD are very good 10. W&B calcs Again not something I use as W&B is never an issue in a CT (perhaps at altitude on a very hot day at MTOW - very rare unfortunately!!) But its mainly a pre-flight feature and so done via desktop version 11. Terrain warnings Yes but of course one of SD's greatest features is the vertical terrain ahead part of the screen. Other comments Reliability of WinCe devices is far better than in the past but Garmin reliability is legendary. Personally I wd not set off without 496 but in flight (apart from map of course!!) my main nav is via SD device. Remember too that SD gives you stff that 496 simply does not:
NOTAM alerts
WX METAR & TAFs always available
Obstacle, airspace and other alerts
Local ATS frequencies at touch of button
Scratchpad
Windpseed & Direction at your location and height
To name a few.
Go for it - you will not regret it - but hang onto your 496 for the time being.
David
