iPad log files
Cardinal
Cardinal
Too Much Forum (814 reputation)Too Much Forum (814 reputation)Too Much Forum (814 reputation)Too Much Forum (814 reputation)Too Much Forum (814 reputation)Too Much Forum (814 reputation)Too Much Forum (814 reputation)Too Much Forum (814 reputation)Too Much Forum (814 reputation)
Posts: 3, Visits: 27
Is there any way of converting the log files from SkyDemon in to a kml file?
I can extract the log files from the iPad using iFile but they won't open in Google Earth.
2high2fastagain
2high2fastagain
Posts: 43, Visits: 98
<Edited because I misinterpreted your original post>
Why not send the iPad log files across to your PC, dump them in the Skydemon logs folder and then call them up on SD on the PC. Then you can export as a GPX. Google Earth should be able to read the GPX file and then I presume you can make a KML file from there (I'm not a Google Earth expert)
Edited 3/12/2012 9:29:46 PM by 2high2fastagain
Cardinal - 3/5/2012 2:45:29 AM
     Anyone???
Cardinal - 3/6/2012 11:33:45 PM
2high2fastagain - 3/12/2012 12:32:58 PM
Marc B - 3/17/2012 10:21:18 AM
charlieoscar2 - 3/25/2012 12:14:55 AM
