iPad log files
Cardinal
Cardinal
Too Much Forum (786 reputation)Too Much Forum (786 reputation)Too Much Forum (786 reputation)Too Much Forum (786 reputation)Too Much Forum (786 reputation)Too Much Forum (786 reputation)Too Much Forum (786 reputation)Too Much Forum (786 reputation)Too Much Forum (786 reputation)
Posts: 3, Visits: 27
Is there any way of converting the log files from SkyDemon in to a kml file?
I can extract the log files from the iPad using iFile but they won't open in Google Earth.
Cardinal
Cardinal
Anyone???
2high2fastagain
2high2fastagain
Too Much Forum (5.8K reputation)Too Much Forum (5.8K reputation)Too Much Forum (5.8K reputation)Too Much Forum (5.8K reputation)Too Much Forum (5.8K reputation)Too Much Forum (5.8K reputation)Too Much Forum (5.8K reputation)Too Much Forum (5.8K reputation)Too Much Forum (5.8K reputation)
Posts: 43, Visits: 98
<Edited because I misinterpreted your original post>
Why not send the iPad log files across to your PC, dump them in the Skydemon logs folder and then call them up on SD on the PC. Then you can export as a GPX. Google Earth should be able to read the GPX file and then I presume you can make a KML file from there (I'm not a Google Earth expert)
Edited 3/12/2012 9:29:46 PM by 2high2fastagain
Marc B
Marc B
Too Much Forum (563 reputation)Too Much Forum (563 reputation)Too Much Forum (563 reputation)Too Much Forum (563 reputation)Too Much Forum (563 reputation)Too Much Forum (563 reputation)Too Much Forum (563 reputation)Too Much Forum (563 reputation)Too Much Forum (563 reputation)
Posts: 2, Visits: 10
First of all, thanks for your software
Question: is it possible to import lognav from skydemon created on pc to Ipad (via cloud, email...)?
Thanks for your answers
Marc B
charlieoscar2
charlieoscar2
Posts: 6, Visits: 169
Today, after one hour and half going around with SkyDemon on board (iPad version last release) along an SD-planned route, I have not been able to save nor recover the flight track that SD was plotting on the map. After landing I stopped the navigation but going into the "Logs" menu I do not find any log related to the last flight I made (only old logs).
Perhaps I made some mistakes, but which is the correct way to quit SD after landing (or during the flight) avoiding the loss of flight logs?
Many thanks for your support, and my congratulations to the developers for this excellent software.
Cosimo
--Charlie Oscar 2
