hard wire ?
tangovictor
tangovictor
Too Much Forum (555 reputation)Too Much Forum (555 reputation)Too Much Forum (555 reputation)Too Much Forum (555 reputation)Too Much Forum (555 reputation)Too Much Forum (555 reputation)Too Much Forum (555 reputation)Too Much Forum (555 reputation)Too Much Forum (555 reputation)
Posts: 6, Visits: 241
Can Sky Demon be hard wired ie as per garmin 296/496 rather than using the internal battery or the cig lighter socket ?
MG
The SkyDemon Mobile MD supports only 5v in via its mini USB socket. What you plug in to the socket doesn't matter as long as it conforms to the voltage specified and in the standard mini USB formfactor.
revilla
revilla
Posts: 15, Visits: 29
Something like http://www.ebay.co.uk/itm/Mini-12V-24V-DC-Port-USB-2-Output-Car-Charger-Adapter-iPod-iPhone-3G-S-4G-4S-/120815127653?pt=UK_MobilePhones_MobilePhoneAccessories_MobilePhoneChargers&hash=item1c21248c65 costs only £1.45 ...
If you take the little circuit board out, hard wire one side to your 12v supply, snip the PC-end socket off a USB lead and solder the wires to the 5v output, porbably want to put it inside a little case from Maplins or similar for neatness - job done.
