Error called Win7, version 2.2.0.31077
John Wighton
John Wighton
Posts: 27, Visits: 87
Following unhandled exeption occurs:
Notice the prog version is win32, is this relevant?
Help?
System.ArgumentNullException: Value cannot be null.
Parameter name: String
at System.Number.StringToNumber(String str, NumberStyles options, NumberBuffer& number, NumberFormatInfo info, Boolean parseDecimal)
at System.Number.ParseInt64(String value, NumberStyles options, NumberFormatInfo numfmt)
at Divelements.Aviation.FlightPlanner.Briefing.Notams.x62f3d5f827405b4e.x69621f7fb16e0e13(Object xe0292b9ed559da7d, x9d30bf0d471b2194 xfbf34718e704c6bc)
at Divelements.Aviation.FlightPlanner.x7e178c0ab5856c7b.OnDownloadFinished(x9d30bf0d471b2194 e)
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.4961 (win7RTMGDR.050727-4900)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v2.0.50727/mscorlib.dll
SkyDemon
Assembly Version: 2.2.0.31077
Win32 Version:
CodeBase: file:///C:/Program%20Files%20(x86)/Divelements%20Limited/SkyDemon/SkyDemon.exe
Assembly Version: 1.0.4226.31074
Win32 Version: 1.0.4226.31074
CodeBase: file:///C:/Program%20Files%20(x86)/Divelements%20Limited/SkyDemon/Divelements.Aviation.DLL
System.Windows.Forms
System
Win32 Version: 2.0.50727.4962 (win7RTMGDR.050727-4900)
System.Drawing
Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900)
Divelements.SandGrid
Assembly Version: 2.2.4.1
Win32 Version: 2.2.4.1
CodeBase: file:///C:/Program%20Files%20(x86)/Divelements%20Limited/SkyDemon/Divelements.SandGrid.DLL
SandDock
Assembly Version: 3.0.6.1
Win32 Version: 3.0.6.1
CodeBase: file:///C:/Program%20Files%20(x86)/Divelements%20Limited/SkyDemon/SandDock.DLL
Divelements.Mapping
Assembly Version: 1.0.4226.31073
Win32 Version: 1.0.4226.31073
CodeBase: file:///C:/Program%20Files%20(x86)/Divelements%20Limited/SkyDemon/Divelements.Mapping.DLL
System.Xml
SandBar
Assembly Version: 1.4.3.1
Win32 Version: 1.4.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Divelements%20Limited/SkyDemon/SandBar.DLL
System.Configuration
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
Microsoft.JScript
Assembly Version: 8.0.0.0
Win32 Version: 8.0.50727.4927
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Microsoft.JScript/8.0.0.0__b03f5f7f11d50a3a/Microsoft.JScript.dll
enabled.
For example:
John Wighton
Europa G-IPOD
John Wighton
John Wighton
It looks like corrupt data in the TAF/METAR download.
Tim, what is the fix?
John Wighton
Europa G-IPOD
This might happen if something were stripping the headers required from a NOTAM data download. Is it still happening?
John Wighton
John Wighton
Cleared now thanks. Has not repeated.
John Wighton
Europa G-IPOD
