Problems with launching InFlight Windows Mobile v0.9.9
srayne
srayne
Too Much Forum (48K reputation)Too Much Forum (48K reputation)Too Much Forum (48K reputation)Too Much Forum (48K reputation)Too Much Forum (48K reputation)Too Much Forum (48K reputation)Too Much Forum (48K reputation)Too Much Forum (48K reputation)Too Much Forum (48K reputation)
Posts: 388, Visits: 8.3K
After installing v0.9.9, Plan works fine but I get an error when trying to run InFlight; at startup:
ERROR: "An unexpected error has occurred in SkyAngel.exe"
DETAILS: "SkyAngel.exe TypeLoadException"
All was well with v0.9.8.
I have tried uninstalling and re-installing using both the CAB and manual copying of renamed files, also uninstalled and re-installed CF3.5.
Any ideas?
Simon
SkyDemon Team (665K reputation)SkyDemon Team (665K reputation)SkyDemon Team (665K reputation)SkyDemon Team (665K reputation)SkyDemon Team (665K reputation)SkyDemon Team (665K reputation)SkyDemon Team (665K reputation)SkyDemon Team (665K reputation)SkyDemon Team (665K reputation)
Posts: 8K, Visits: 9.1K
Not sure why you're download a CAB file at all; the Windows CE software is now shipped as a ZIP file for easy extraction. Having said this, I doubt it will make a difference to this specific issue.
This is something that a couple of people have reported, but the majority of people don't seem to have a problem. So far I haven't been able to work out why the software has stopped working on this small number of devices; there doesn't seem to be a common factor.
What version of Windows CE is it running?
If you email me, I'll try sending you a test build to narrow down the cause.
srayne
srayne
Sorry I didn't make it clear that InFlight problem occurs on Windows Mobile 6.0 device - hence use of CAB file
Email sent as requested.
Simon
srayne
srayne
Maybe you could merge this topic with the "Instructions for installing on PDA" thread where you seem to be discussing the same problem with RichardP?
Phild
Phild
Too Much Forum (674 reputation)Too Much Forum (674 reputation)Too Much Forum (674 reputation)Too Much Forum (674 reputation)Too Much Forum (674 reputation)Too Much Forum (674 reputation)Too Much Forum (674 reputation)Too Much Forum (674 reputation)Too Much Forum (674 reputation)
Posts: 8, Visits: 34
I am getting this error as well with 0.9.9 on a WinCE device (Navigo V2).
Windows CE
Version 5.00
All was fine with 0.9.8 and previous versions.
Phil
adsdjo
adsdjo
Too Much Forum (556 reputation)Too Much Forum (556 reputation)Too Much Forum (556 reputation)Too Much Forum (556 reputation)Too Much Forum (556 reputation)Too Much Forum (556 reputation)Too Much Forum (556 reputation)Too Much Forum (556 reputation)Too Much Forum (556 reputation)
Posts: 3, Visits: 22
same here - always worked until this version.
On a navigo same as above.
This has now been fixed. I might post an early release this week since a few people seem to be getting this error. Thanks for reporting it.
Topcat
Topcat
Too Much Forum (532 reputation)Too Much Forum (532 reputation)Too Much Forum (532 reputation)Too Much Forum (532 reputation)Too Much Forum (532 reputation)Too Much Forum (532 reputation)Too Much Forum (532 reputation)Too Much Forum (532 reputation)Too Much Forum (532 reputation)
Posts: 6, Visits: 21
Still having this error with iPAQ 314 running CE 5.
