miaelch
Visits: 4
+x+xThe issue we are talking about is that the empty weight in SkyDemon does not include the unusable fuel, but the empty weight in real life does. I posted two possibilities how to deal with this. Maybe I didn't make clear enough the disadvantages of my method No. 2 (that is, to manually calculate the empty weight without fuel and the empty CG without fuel and to enter these values into SkyDemon).
1. I assume that most SkyDemon users are not aware of the fact that they have to do such calculations at all. 2. It introduces a source for calculation errors. The purpose of the W&B feature is that we do not have to calculate manually with moments. 3. It is impossible to check the correctness of the aircraft profile without calculating. If the aircraft profile is provided by a flight school or a flying club then you need to explain to everybody why it is indeed correct.
And yes, the error may be not so big. But at some point in time in the past it was decided that the unusable fuel is important enough to be included as a feature into SkyDemon. And in my opinion, if there is a feature then it should be correct.
Surely the empty weight in SkyDemon is whatever you want it to be? It doesn’t decide for you whether unusable fuel is included or not. It is not. In SkyDemon the take-off mass is calculated as empty weight plus fuel on board (plus crew plus luggage). Analogously for the CG. This leads to the consequences that I described earlier: You have to work-around with the empty weight or with the fuel definition, or, otherwise, if you enter the values from the aircraft weight sheet into the aircraft configuration in SkyDemon AND later enter the values from the fuel gauges into the SkyDemon route details then you will get a wrong result for the gross weight and CG.
Visits: 32K
miaelch
Visits: 4
KimW
Visits: 0
I dont see the problem either. If the dry W&B does not include unusable fuel. Correct it with the arm and enter correct number into Skydemon. I see no reason for the software to cater for that.
PS: Apologies for the potential patronizing comment, my point was that the accuracy on the total W&B is not perfect, but I agree, why would you start with an error to begin with.
Visits: 32K
+x"Why is that a disadvantage?" - I think I made it quite clear. ..... I am wondering why people are replying who have nothing to contribute except saying "I don't care about this". I don't think you did make it clear. I still can't see why it's a problem if you've configured your aircraft profile correctly. I'm contributing, because either I, or you, are missing something. If it's me, I'd like to understand where I'm going wrong.
miaelch
Visits: 4
"passenger moving their legs" - Apart from the fact that there are airplanes whose unusable fuel weights more than a pair of legs (e. g. A36), it is a matter of the software being correct or not.
KimW
Visits: 0
If the W&B of unusable fuel is a concern you are very precise with the weighing procedures, to the point where passenger moving their legs would require an updated W&B.
Seems this is subject to the pilot overthinkers club - which I'm also a member of TBH.
Visits: 32K
+x1. Configure the SkyDemon empty weight as the real world empty weight (including unusable fuel), configure the SkyDemon empty CG as the real world empty CG (including unusable fuel), configure the SkyDemon overall fuel capacity as the real world usable fuel capacity, and configure the SkyDemon unusable fuel capacity as zero. During flight planning, set the SkyDemon overall amount of fuel to the real world amount of usable fuel. The disadvantage of this approach is that the SkyDemon overall amount of fuel differs from the real world overall amount of fuel during each flight preparation.
Weight and balance will be correct, endurance will be correctly calculated.
miaelch
Visits: 4
To bring up this topic again... From what I understood and experimented: 1. The unusable fuel configured in SkyDemon does not contribute to the endurance/range calculated by SkyDemon. 2. SkyDemon assumes that the empty weight does not include the unusable fuel. In the real world, the empty weight includes the unusable fuel. There are two ways for the user to deal with this. 1. Configure the SkyDemon empty weight as the real world empty weight (including unusable fuel), configure the SkyDemon empty CG as the real world empty CG (including unusable fuel), configure the SkyDemon overall fuel capacity as the real world usable fuel capacity, and configure the SkyDemon unusable fuel capacity as zero. During flight planning, set the SkyDemon overall amount of fuel to the real world amount of usable fuel. The disadvantage of this approach is that the SkyDemon overall amount of fuel differs from the real world overall amount of fuel during each flight preparation. 2. Configure the SkyDemon empty weight as the real world empty weight minus real world unusable fuel weight, configure the SkyDemon empty CG as the real world CG of the empty aircraft without unusable fuel (needs to be calculated), configure the SkyDemon overall fuel capacity as the real world overall fuel capacity, and configure the SkyDemon unusable fuel capacity as the real world unusable fuel capacity. During flight planning, set the SkyDemon overall amount of fuel to the real world overall amount of fuel. The disadvantage of this approach is that you need to calculate the values for configuring the SkyDemon empty weight and empty CG, and it is impossible to quickly cross-check the configuration against the aircraft weight sheet before flying or when importing the profile from a flight school or flying club. It would be great if SkyDemon could add a checkbox "empty weight includes unusable fuel" in the aircraft configuration. I guess it could be easy to implement because internally SkyDemon could just use the second approach from above.
InfrequentFlyer
Visits: 732
ckurz7000 (8/5/2015) The empty weight of an aircraft includes unusable fuel as well as all other fluids required to operate the aircraft. The fuel gauges are required to read "zero" when all USABLE fuel is gone. So why don't you define the tank volume as the amount of usable fuel and include the weight of unusable fuel in the empty weight of the aircraft? That's how it is supposed to be done.
-- Chris.Chris, do you have a definitive source for that? The Weight and Centre of Gravity Schedule in front of me includes: "The basic (empty) weight includes the weight of NIL gals unusable fuel and FULL oil" (plus a basic equipment list). I've done some Googling, and I won't bore you with the details, but in various sources (including various parts of FAA 8083) empty weight may or may not include oil, and "unusable fuel" included in basic empty weight may mean "The unusable fuel supply for each tank must be established as not less than the quanitty at which the first evidence of malfunctioning occurs under the most adverse fuel feed condition occuring under each intended operation and flight maneuver involving that tank." Alternatively, unusable fuel is sometimes defined as the same as "undrainable fuel". Or, as in the case I've been looking at, it may not be included at all. The long and short of it: don't assume theoritical endurance figures allow for unusable fuel unless you've checked.
