Adding unusable fuel in aircraft profile
http://forums.skydemon.aero/Topic11847.aspx
By Mike@EDTG - 4/23/2014 12:01:06 PM
Unfortunately there is no option to define the amount of dead fuel within the aircraft profile. The only way to do this right now is adding an additional w&b station including weight&arm of the unusable fuel. Reduce amount of max fuel capacity in the profile to usable & everything will be fine. Any plans to exclude dead fuel in future releases?
P.s. please ad gasoline/diesel to fuel type options
-mike
By GalaxyzA11+ - 10/22/2026 5:55:02 PM
GalaxyzA11+ - 10/18/2026 10:17:31 PM
I'm trying hard to understand all of this.
In my mind I can use unusable fuel feature if the empty weight does not incluse it,
And  wont use it if it is still included in empty weight and CoG data.
Btw the key is "what does the manual book say " ? Include or not ?
If included, the gauge or the stick should start at included =  differential zero
If not included, the gauge or stick should start at zero = absolut zero and you use unusable fuel feature.
Of course if you say 10L included in empty weight but , but gauge indicate 10L at unusable, and the CoG does not include it and so on, then you cannot solve the problem because your data are uncorrelated.
What I mean is that your data must be correct/coherent with the first point -unusable fuel  is included or not in data book- and then the other data depends on that first point.
So far I dont see something wrong in SkyDemon.
(No need of a tick box ?)
HTH.
Sorry I was false here :
For both case, the stick or fuel gauge should indicate zero with unusable fuel included.
If the unusable fuel weight is included in the empty weight, you don't use the"unusable" fonction.
If the unusable fuel weight is not included in the empty weight, you use the unusable fuel fonction.
The mistake in point 1 and 2 in the previous post from @miaelch is to mix volumes, weight, usable and unusable fuel.
Weight is weight, volume is volume.
So no confusion will appear.
