Checklist - sort and log
Nik
N
Too Much Forum (167 reputation)Too Much Forum (167 reputation)Too Much Forum (167 reputation)Too Much Forum (167 reputation)Too Much Forum (167 reputation)Too Much Forum (167 reputation)Too Much Forum (167 reputation)Too Much Forum (167 reputation)Too Much Forum (167 reputation)
Posts: 16, Visits: 0
Hi
Very happy with checklist. Something I searched the last few month on app stores - and now on my loved tool!!! Thanks
Some improvements (found on android smartphone)
- Order of checklist would be nice. Now they are in the order I created.
- top right I can go to next or previous - I think its the same as above. the order seams to be of the creation not of the list
- once one is completed (or also in between), add the status in the log. This way we can confirm in a ramp check or insurance case, that we did our checks.
KimW
K
Posts: 59, Visits: 0
Also really happy with the checklist feature, but missing a way to rearrange in desired sequence.
Hope SD team can look at that soon 🙏
KimW
K
Tested checklist again and is really happy with the feature, but the inability to sort a sequence of checklists within a group is highest on my wishlist. I've found the workarounds to be having only one in each section or deleting all and recreating in the desired sequence, as they get sorted by create time by default.
Anyone knows if SD team have plans to add this feature in future version?
Can you show a screenshot of the problem? We added tools to reorder the sections within checklists, and to reorder the items within those sections.
KimW
K
Tim Dawson - 1/5/2026 11:52:30 AM
I have two planes setup as examples. For the Rockwell Commander 114B I have created them in the sequence, I would like them to be during the flight. This way I can just move forward as the flight progresses through the phases.
For the Grummen I have created them no in the order I prefer them to be in. I would like a way to re-order them, similar to the way each checklist item can be reordered within a checklist.
Hope it makes sense Smile
PS: If my use of it is not as intended, I'm happy to adapt, but for me this keeps the checklists reasonably short and in good order.
Thanks. You've encoded them all as individual checklists, whereas I think we anticipated people using sections within checklists more. There's nothing wrong with the way you've done it though, and clearly we need to add tools to move them up and down where users have chosen to create them this way.
KimW
K
Sounds great Tim.
I have mixed the options and used sections within checklist where I wanted to keep one continuous flow. Used multiple checklists where I would like to avoid having to scroll deep to find the section needed.
I like that both options are there, just missing the option to re sequence the checklists.
I've been hoping for the checklist feature for quite some time and I really enjoy using it. I find it very valuable and is grateful you invested in this 🙏.
Nik
N
Same here, still after some flights, the problem remains. I fly experimental, so I have my own checklists. And I missed to enter them in a clean setup at the beginning. My bad, but sort could save.
As my order of the checks is not handy, I use the checklists only for preparing a flight and not in flight. When I can rearange, I would use it on the flight as well.
TimT
TimT
Posts: 98, Visits: 92
Nik - 4/4/2026 3:03:41 PM
Hi Nik, I seem to be able to re-order individual checklist items, subsections, and also sections, without restriction. So I don't immediately see your issue.
Of course, you can also delete the checklist that didn't work and start from scratch (sometimes SD 'helps' you to lose what you had, initially a bit of a nuisance, but certainly second time round, your checklist will even be better ;-) .
What makes sense is to first author your custom checklist in a spreadsheet file, and use this as a master copy. This would help you to get everything right conceptionally, before typing it into SD. And if there was a data lass on your portable device, all your creative work is still in your backup spreadsheet file. You would still need to type it in again into SD (at least as along as SD doesn't offer a csv import for checklists...) but at least you don't need to re-invent your checklist again.
Nik
N
I'm fine now too. Rearange is now working and I'm happy with it. Just missing the function, that checks are recorded with the logs...
