GAJ52
Visits: 66
How do I set up the flight altitude in the PC Windows version of Skydemon. On the Ipad its under 'Flight Details' but I can't find this in the Windows version. Glen
Visits: 15K
+xHow do I set up the flight altitude in the PC Windows version of Skydemon. On the Ipad its under 'Flight Details' but I can't find this in the Windows version. Glen Bottom right of the screen and click on the Flight Details tab.
Mike _________________________________________ Samsung Galaxy Tab A8 – Android 11.0 & SD 4.1.2 Huawei P30 – Android 11.0 & SD 4.1.2 PC – Windows 10 (Home Ed) Version 22H2, Build 19045.6396, SD 4.1.2
GAJ52
Visits: 66
Thanks Mike, I was looking in the Menu options at the top of the page.
Glen
landrus
Visits: 1
+xThanks Mike, I was looking in the Menu options at the top of the page.
Glen Hi, I am having the issue that on Windows skydemon only accepts IFR heights (2000, 3000, ...), instead of VFR heights. If I try to enter such a height, it does not accept it.
Visits: 15K
+x+xThanks Mike, I was looking in the Menu options at the top of the page.
Glen Hi, I am having the issue that on Windows skydemon only accepts IFR heights (2000, 3000, ...), instead of VFR heights. If I try to enter such a height, it does not accept it. Make sure that in the Flight Details sub-window (bottom right of screen) Flight Rules is set to VFR.
Visits: 15K
Glen Hi, I am having the issue that on Windows skydemon only accepts IFR heights (2000, 3000, ...), instead of VFR heights. If I try to enter such a height, it does not accept it. In the Flight Details sub-window (bottom right of screen) make sure that Flight Rules is set to VFR
Visits: 29K
I agree, there appears to be a bug.
Setting IFR should present only the round thousand altitudes. Setting VFR should present only the thousand+500 altitudes Setting 'Mixed' should present both.
That's the way the iOS/iPadOS version works, and the Windows version should behave in the same manner.
Posts: 8.2K,
Visits: 9.6K
You can type any altitude (or flight level) you like into the box. landrus, when you say "it does not accept it", what exactly are you typing and what happens?
landrus
Visits: 1
+xYou can type any altitude (or flight level) you like into the box. landrus, when you say "it does not accept it", what exactly are you typing and what happens? I was typing in values, as they appeared from SyDemon. So, let's say it was 5,500 feet. When you click in the field that text would still be in there. You cannot change that value, any change will be denied. It does accept pure numbers (so, in my case I would change the text in the input filed to 6500). So, either change the value in the field when you edit it, or allow to read the values you actually display in there.
Posts: 8.2K,
Visits: 9.6K
Ah, I see what you mean. The value is formatted in a "friendly" way with units, but what it accepts is a simple number. You're right, that isn't ideal. We will get it changed for the next version.
