F70100
Visits: 7
Full disclosure: I'm coming back to VFR from 25 years of airline flying so by all means take all this with a pinch of salt.
I'm finding one of the terms used in SkyDemon to describe the various categories of fuel required for any particular flight somewhat misleading.
SkyDemon uses the term "Holding Time" fuel to describe what in IFR flying would be "Final Reserve" fuel. i.e. the quantity of fuel loaded which you hope never to have to burn. If it becomes apparent that an IFR flight will land with less than the full amount of Final Reserve fuel on board, it is expected that an emergency will be declared. IFR flight planning also requires a minimum of 30 minutes "holding fuel" to be carried, but this is fuel that you can use if required, and is in addition to Final Reserve fuel.
Part-NCO requires VFR flights to carry "minimum fuel reserves", and this is analogous to "final reserve" in IFR.
I respectfully suggest that the term "Holding Time" be changed to "Minimum Fuel Reserves" to emphasise the point that this fuel is the last drop available, and align the terminology with Part-NCO. If fuel is required for "holding", it might more appropriate to account for it separately, or even add it to the contingency fuel.
I'm new around here; not trying to change the world, just thinking out load really.
marioair
Visits: 1
SD team - can this be checked again? The fuel plan uses term “holding time” Based on this the fuel plan suggests you’ll land on vapours with no final reserve. Suggestion is to add an optional final reserve and use 30/45 based on flight rules
lhe
Visits: 445
I second the suggestion by F70100. With a change of part-NCO the other year, it is clear from EASA regs that "Final reserve fuel" applies to both VFR and IFR. This is an amount that must be in the tanks after landing. If any parts of this reserve gets used in flight, it is an automatic emergency.
Of course holding fuel and contingency fuel are still relevant, but the pilot should be able to specify at least the holding fuel for each flight separately.
I see that over the years there have been suggestions in this forum to allow for separate entries of contingency fuel, holding fuel and extra/discretionary fuel (fuel that the pilot for other reasons considers necessary in addition to the other amounts of fuel). That would be a good idea, too. As it is I have to keep track of these manually during flight planning.
Posts: 8.3K,
Visits: 10K
I think I've said previously on another thread here that we can't really change the "holding time" way of doing things that we currently have, because thousands of aircraft profiles have been set up with this carefully set.
However, I'm definitely open to adding another fuel line in our fuel calculations, and it sounds like "Final Reserve Fuel" would fit the bill for everyone, is that right? You would enter an amount per aircraft (not a time) and that would simply be added to your fuel calculations and weight and balance too of course.
F70100
Visits: 7
+xI think I've said previously on another thread here that we can't really change the "holding time" way of doing things that we currently have, because thousands of aircraft profiles have been set up with this carefully set.
However, I'm definitely open to adding another fuel line in our fuel calculations, and it sounds like "Final Reserve Fuel" would fit the bill for everyone, is that right? You would enter an amount per aircraft (not a time) and that would simply be added to your fuel calculations and weight and balance too of course. Sounds good to me Tim; I'm sure folks can enter a Final Reserve Fuel number representing 10, 30 or 45 mins worth of fuel according to the requirements of any particular flight, and if that means that holding fuel has to be reduced to zero to accommodate it, that would highlight the issue. This would be a big help from an instructing perspective for me.
Keep up the good work!!
lhe
Visits: 445
+xYou would enter an amount per aircraft (not a time) and that would simply be added to your fuel calculations and weight and balance too of course. That would be helpful, but the time corresponding to this amount should be included in the endurance figure as well. Even if you're not supposed to use it, it can still be used in an emergency.
Visits: 31K
I’m not keen on that approach. Like it or not, there are many pilots who don’t fully understand Part NCO and its definition of emergency fuel, and may be lured into thinking it’s some optional thing. Anyway, SD does nt know what consumption I’ve assumed when I’ve specified an amount of fuel in litres I may have specified my legal IFR 45 minutes using the required method and SD show it as a different calculated time. I would rather see the PLOG changed to show an endurance figure plus the emergency amount separately.
lhe
Visits: 445
+xI’m not keen on that approach. Like it or not, there are many pilots who don’t fully understand Part NCO and its definition of emergency fuel, and may be lured into thinking it’s some optional thing. Anyway, SD does nt know what consumption I’ve assumed when I’ve specified an amount of fuel in litres I may have specified my legal IFR 45 minutes using the required method and SD show it as a different calculated time. I would rather see the PLOG changed to show an endurance figure plus the emergency amount separately. There are two different but related issues. - That the pilot understands how long it will take before the aircraft runs out of fuel - That the endurance figure in flight plans reflects how long it will take before the aircraft runs out of fuel
F70100
Visits: 7
If there’s a line for Minimum Fuel Reserves in the fuel calculation, the user gets to decide how many litres to allocate for this use. The number of litres chosen will depend on the power setting / consumption rate, and the time that the fuel is required to last for. Both of these are decided by the user.
My motivation for raising this issue is that there is no obvious way in the SkyDemon fuel breakdown to account for Part - 21 minimum fuel reserves (or non Part - 21 recommended 30 minutes worth). I’m hoping that the SkyDemon team can find a way to introduce this.
Posts: 8.3K,
Visits: 10K
We're implementing a Final Reserve fuel line in our next version, which I am pretty sure will be specified in minutes. In addition, it will be possible to reduce the existing (and somewhat anachronistic) Holding Time value down to zero.
