Bicester airfield missing
Rob Hart
Rob Hart
SkyDemon Team (9.6K reputation)SkyDemon Team (9.6K reputation)SkyDemon Team (9.6K reputation)SkyDemon Team (9.6K reputation)SkyDemon Team (9.6K reputation)SkyDemon Team (9.6K reputation)SkyDemon Team (9.6K reputation)SkyDemon Team (9.6K reputation)SkyDemon Team (9.6K reputation)
Posts: 77, Visits: 454
I have removed the ICAO code from Bicester's entry, and this should take effect from the next chart update which I believe is scheduled for the 27th.
pschartau
pschartau
Too Much Forum (7.3K reputation)Too Much Forum (7.3K reputation)Too Much Forum (7.3K reputation)Too Much Forum (7.3K reputation)Too Much Forum (7.3K reputation)Too Much Forum (7.3K reputation)Too Much Forum (7.3K reputation)Too Much Forum (7.3K reputation)Too Much Forum (7.3K reputation)
Posts: 55, Visits: 1.2K
Hi Rob / Tim,
it appears that Bicester has gone back to EGDD. This ICAO code does not exist - flight plans will not be accepted with EGDD as departure or arrival. Could you please change it back to ZZZZ.
Best Regards,
pschartau
pschartau
pschartau
Thank you!
Rob Hart
Rob Hart
I have made this change, and you should see it take effect in the next ARIAC update (28th July).
Thanks for the bump!
pschartau
pschartau
pschartau (18/04/2011)
Sorry just to re-iterate, can we change Bicester to ZZZZ for flight plan filing purposes?
Just to bump this topic, sorry. Bicester's code EGDD is not recognized and causes problems when filing flightplans. It would be great if the code could be removed so that flightplans are files with ZZZZ as origin / destination.
Thanks.
pschartau
pschartau
pschartau
pschartau
Many thanks. I think the EGDD code is no longer valid so it should probably be a ZZZZ.
I am told we have a plate for this airfield in the forthcoming 2.1 release, due on Thursday.
pschartau
pschartau
As the title says, Bicester airfield (EGDD) is missing from the UK chart. It was there in a previous version. Would be great if it could be included again.
Thanks.
