Importing routes into a Garmin GTNx50xi via an SD card - has anyone actually done this?
Importing routes into a Garmin GTNx50xi via an SD card - has anyone...
Posts: 645, Visits: 31K
SkyDemon now supports exporting of flight plans in Garmin GTN flight plan format. According to the GTNxi manual, I should be able to drop these on to an SD card, and import them to my 650xi via an option on the ‘Catalogue’ menu.
Using neither a blank card, nor the Navdata card, seems to work, so either the SD export format is not actually being recognised, or I’m doing something daft.
Has anyone else tried to do this?
For the record, I have now discovered the secret to making this work.
For the GTN to recognise the presence of routes to be imported, they have to be placed into a folder named \FPL on the SD card.
Unfortunately this detail is not specifically mentioned in the GTNxi series user manual!
Thanks Graham.
Peter Sp
P
Forum Member (37 reputation)Forum Member (37 reputation)Forum Member (37 reputation)Forum Member (37 reputation)Forum Member (37 reputation)Forum Member (37 reputation)Forum Member (37 reputation)Forum Member (37 reputation)Forum Member (37 reputation)
Posts: 4, Visits: 8
grahamb - 5/16/2023 10:18:26 PM
For the record, I have now discovered the secret to making this work. For the GTN to recognise the presence of routes to be imported, they have to be placed into a folder named \FPL on the SD card.Unfortunately this detail is not specifically mentioned in the GTNxi series user manual!
Graham,
At last a solution!
I've been searching high and low for a way to make it work.  Uploading user waypoints was a matter of following the instructions, but not for the routes.
You say a folder named \GTN has to be used.  "\" is not an allowed character for folder names, so I guess that the folder is called GTN.  Am I right?
Cheers!
Peter
Peter Sp - 10/6/2024 2:27:24 PM
Graham,
At last a solution!
Cheers!
Peter
The required folder name is FPL, not GTN.
The backslash is just the required delimiter.
Peter Sp
P
Posts: 4, Visits: 8
grahamb - 10/6/2024 9:03:54 PM
Graham,
At last a solution!
Cheers!
Peter
Thanks Graham,
Finger trouble on the folder name!  I've checked what I used on the SD card and have the right one.  I have created two routes using existing GTN650 waypoints on one card - they should work.  On another, I have a route with two waypoints which aren't on the GTN650 to see what a failure looks like.
Thanks also for the clarification on the delimiter.
Peter
