Frosinone (LIRH) frequencies
ardix
a
Too Much Forum (257 reputation)Too Much Forum (257 reputation)Too Much Forum (257 reputation)Too Much Forum (257 reputation)Too Much Forum (257 reputation)Too Much Forum (257 reputation)Too Much Forum (257 reputation)Too Much Forum (257 reputation)Too Much Forum (257 reputation)
Posts: 19, Visits: 24
Hello, I've noticed some problems with the frequencies.
Frosinone Approach 122,600 MHz is not showing if you click anywere inside che CTR1 and CTR2, but only if you click directly over the airport.
The main Tower frequency is 119,350 MHz (now indicated as "Frosinone Tower Tower")
The other Tower/Approach frequency is 122,100 MHz, which is indicated as well as "Frosinone Tower Tower", it's a common general/backup frequency, used in a lot of mil or civ/mil airports here in Italy.
Unfortunately I don't have access to MILAIP, so you have to somehow trust what I say, which is based on real feedbacks from the ATC over there.
Regards.
Diego
Posts: 8.1K, Visits: 9.3K
Thanks Diego, we'll take a look into this and get back to you.
We should have most of these points addressed in our next chart update.
ardix
a
Hi Tim, unfortunately there is still something missing...
The approach frequency is now correctly depicted inside the controlled airspace, but the tower frequency (119,350 MHz) is missing!
Diego
It is correct that the Frosinone CTR frequency is the APP frequency. This matches what the AIP says is the most appropriate frequency to use for the airspace.
ardix
a
Tim Dawson - 9/30/2022 9:10:27 AM
The TWR freq is missing indeed. Check AIP ENR 2.1.3-5
I confirm that both tower frequencies will be included in our next chart update.
