Stacking of airspace is upside down
Gerhard66
G
Posts: 175, Visits: 358
The stack of airspace’s in the what’s here menu seems to be upside down.
Probably just a little bug and hopefully not a feature ;-)
Airspace is listed from the surface upwards. That is deliberate, as people are more likely to want to know about lower airspace than higher airspace, on average.
publicom
Too Much Forum (623 reputation)Too Much Forum (623 reputation)Too Much Forum (623 reputation)Too Much Forum (623 reputation)Too Much Forum (623 reputation)Too Much Forum (623 reputation)Too Much Forum (623 reputation)Too Much Forum (623 reputation)Too Much Forum (623 reputation)
Posts: 40, Visits: 116
Tim Dawson - 2/22/2022 10:03:45 AM
It is extremly confusing as the list is right beside the Column which is the other (right) way round.
Also, why should people more likely want to know about lower airspace? I fly most of the time between FL 65 and 95.
But even those, who do can easily get used to look on the bottom first.
Firstly because most people fly lower than you do, and secondly because many people use SkyDemon on smaller screens, if we showed higher airspaces first in the list, the lower airspaces are more likely to need a scroll of the screen in order to see.
publicom
Tim Dawson - 5/16/2022 9:44:45 AM
I agree. But that does not mean, that the order is right or makes sense. It means, that the default scroll position should be at the bottom, not the top.
No, it really doesn't. Even more often-accessed items such as waypoints are at the top of the list.
The stack on the left is a representation of spacial features and it makes sense that it's laid out pictorially. The list on the right is a list of what's under your finger, and like most lists it's best with the most frequently-accessed items at the top.
I understand you dislike the fact the different sides are laid out differently, but it seems to work for most people so I'm afraid it's not likely we'll change it any time soon.
Gerhard66
G
Why not simply set the default scroll position to the bottom?
Because then you'd need to scroll up to get to the most-frequently-accessed items in the list, such as waypoint creation and airfield information.
mapl99
m
Too Much Forum (269 reputation)Too Much Forum (269 reputation)Too Much Forum (269 reputation)Too Much Forum (269 reputation)Too Much Forum (269 reputation)Too Much Forum (269 reputation)Too Much Forum (269 reputation)Too Much Forum (269 reputation)Too Much Forum (269 reputation)
Posts: 6, Visits: 5
Gerhard66 - 2/25/2023 5:26:47 AM
Or make it configurable. So everyone can decide which is best for him or her.
Gerhard66
G
I understand Tims arguments.
A solution could be to have separate scrolling areas, one for airspaces in „correct“ order and one for the additional information.
But this construction would be even more confusing, especially on small screens.
So I’m happy with the current implementation - as far as no one has a better idea.
