Reverse Route, but Alternate retained?
SkyDemon Team (707K reputation)SkyDemon Team (707K reputation)SkyDemon Team (707K reputation)SkyDemon Team (707K reputation)SkyDemon Team (707K reputation)SkyDemon Team (707K reputation)SkyDemon Team (707K reputation)SkyDemon Team (707K reputation)SkyDemon Team (707K reputation)
If you have an alternate planned, and your current position indicates you're closer to that course-to-alternate than any of your other planned legs, then SkyDemon will indeed assume you're flying your alternate leg. This is by design, and our rationale for not automatically wiping out your alternate when you reverse your route remains the same as described earlier in this thread.
tcx32fr
t
Junior Member (22 reputation)Junior Member (22 reputation)Junior Member (22 reputation)Junior Member (22 reputation)Junior Member (22 reputation)Junior Member (22 reputation)Junior Member (22 reputation)Junior Member (22 reputation)Junior Member (22 reputation)
Posts: 2, Visits: 3
tcx32fr - 7/10/2021 11:23:43 AM
Tim Dawson - 7/1/2019 9:14:06 AM
We discussed this at a recent development meeting. Because of the fact that people often reverse their route then immediately reverse it again (just to inspect it) we would not remove the alternate, as that would leave them with their route in an altered state after the two actions.
We therefore leave it to the user's discretion, on purpose, to change or remove their alternate.
Hello
I used yesteday this feature 'Reverse' and indeed my previous alternate was retained. But I was not aware of this choice of retaining it and only noticed it in flight on my return flight.
Now I got quite weird behavior while returning. Instead of having my estimate ETA & ETE for my destination = END on the top of the NAV screen, I was getting my previous route alternate as the END,and ETA was current time and ETE = 0. I have taken sceenshots, see below.
Though I can understand a choice has been taken to retain the alternate after using "Reverse" - which I personally don't like - at least SD should not present to the pilot wrong information.
Practically I had to kill my flight plan doing a Direct to, then unlock the leg to add additional waypoints, then I got correct estimates for my destination = END
Thanks for any comment !
By the way I just noticed that the destination and the alternate seem to be mixed up since the end of the pilot log show " LFBR Muret Lherm and just below LFEQ Quiberon". Seem Dest & Alt are merged ...
tcx32fr
t
Posts: 2, Visits: 3
Hello
daerden
daerden
Posts: 14, Visits: 30
I like the Reverse Route option. However, the reversed track retains the alternate destination, which doesn't make a lot of sense.
Minor inconvenience, but I would suggest removing the alternate when the user asks to reverse the route.
