Change leg properties for a whole route
Altomar718
A
Too Much Forum (124 reputation)Too Much Forum (124 reputation)Too Much Forum (124 reputation)Too Much Forum (124 reputation)Too Much Forum (124 reputation)Too Much Forum (124 reputation)Too Much Forum (124 reputation)Too Much Forum (124 reputation)Too Much Forum (124 reputation)
Posts: 11, Visits: 7
Hi All
If a route is planned, and all legs are set to the "use route level option" say 2,300 feet, and you then decide to change the whole route to a high or lower altitude, is there a way of changing ALL the legs in one go as opposed to clicking the magenta line > leg properties > unticking use route level and manually changing that legs altitude in the level box for each leg that has been planned ?
Perhaps a route has been created previously and then the cloud base is lower, so you decide to fly at a lower level, can the whole route be changed in a simpler way ? - Thanks in advance
Altomar718 - 6/13/2021 8:54:16 AM
pilot-byom - 6/13/2021 9:10:00 AM
Altomar718 - 6/14/2021 6:59:15 AM
