Skydemon and Flightplanner
aviador
a
Junior Member (17 reputation)Junior Member (17 reputation)Junior Member (17 reputation)Junior Member (17 reputation)Junior Member (17 reputation)Junior Member (17 reputation)Junior Member (17 reputation)Junior Member (17 reputation)Junior Member (17 reputation)
Posts: 2, Visits: 8
Hello all,
is there a pssibility to import planned flights from ifos Flightplanner to skydeamon?
Thanks für your help
I don't know Flightplanner, but Skydemon uses pretty easy to read XML files for flight plans. So, if you open one of the Flightplanner files it should be rather simple to see what is necessary.
Posts: 8.2K, Visits: 9.5K
There is an industry-standard GPX file format that most apps export and import. If the other app you're using can export/save your route in GPX format, you can open it in SkyDemon.
aviador
a
Posts: 2, Visits: 8
Hi, thanks for your answers. The GPX-Format is the solution, I've saved my routes in this format and imported them in SkyDeamon. That works fine.
