Track up in briefing pack option
Calimero2312
C
Junior Member (23 reputation)Junior Member (23 reputation)Junior Member (23 reputation)Junior Member (23 reputation)Junior Member (23 reputation)Junior Member (23 reputation)Junior Member (23 reputation)Junior Member (23 reputation)Junior Member (23 reputation)
Posts: 2, Visits: 0
I did not find any option to print the track up in the briefing pack
is it existing or would it be a suggestion for future versions
Best
Alexis
How would you imagine this would work, given that your journey will be comprised of many legs of different tracks? A new page for every leg?
Tim Dawson - 3/8/2021 10:00:02 AM
'The Daily Prophet'-Style may solve the problem ;-).
Calimero2312
C
Posts: 2, Visits: 0
Yes maybe something like that depending of the chosen scale you could have from1 to several pages per leg and then the orientation of the map change for the next leg,
One could make a booklet to turn the pages and thus always see what you have in front of you eyes
To me that would make a good backup of the track up display option you have on the ipad in navigation : the daily prophet style indeed ;-)
What if there are many small legs, that would easily fit on one page? Would we nevertheless produce many pages with slightly differing orientations?
At some point I suspect it might be easier to simply rotate the printed page.
Tim Dawson - 3/9/2021 9:33:33 AM
'Rotate' is a good topic. When will we get the option to rotate PDF in Skydemon?
There are quite some PDF, which when simply opened are not in 'read position'.
I don't know; have you flagged it with support?
