Visits: 388
It is been a while since I used the PC version, but when reviewing my todays flight I realized the flight duration display is gone under Flight Details section, but now I have a 'costs' display, which I don't care. When did the flight duration disappear or is is hidden somewhere else?
*update* Ok, saw the same is now true for 'Flight Details' from the Route menu on the mobile device, maybe inherited. Question: I don't care for Endurance or Flight Cost when looking at Flight Details, I need at least Flight Duration there - any chance to get that?
Visits: 32K
+xIt is been a while since I used the PC version, but when reviewing my todays flight I realized the flight duration display is gone under Flight Details section, but now I have a 'costs' display, which I don't care. When did the flight duration disappear or is is hidden somewhere else?
*update* Ok, saw the same is now true for 'Flight Details' from the Route menu on the mobile device, maybe inherited. Question: I don't care for Endurance or Flight Cost when looking at Flight Details, I need at least Flight Duration there - any chance to get that? On a mobile device, the total distance and duration are given right there in the centre at the top of the chart.
Visits: 388
+xOn a mobile device, the total distance and duration are given right there in the centre at the top of the chart. I know that, but also in the mobile version distance and duration are no longer where it is expected - in Flight Details. *update* Ok, found it as a small label on the uttermost top right of the screen, not the best solution. Thread can be closed.
Visits: 32K
+x+xOn a mobile device, the total distance and duration are given right there in the centre at the top of the chart. I know that, but also in the mobile version distance and duration are no longer where it is expected - in Flight Details. *update* Ok, found it as a small label on the uttermost top right of the screen, not the best solution. Thread can be closed. On the PC version, it is given in brackets after the landing time in the 'Timings' section.
Visits: 388
+xOn the PC version, it is given in brackets after the landing time in the 'Timings' section. Which 'Timings' section do you refer to, the one visible only after generating a PLOG?
Visits: 32K
+x+xOn the PC version, it is given in brackets after the landing time in the 'Timings' section. Which 'Timings' section do you refer to, the one visible only after generating a PLOG? No, the one in Flight Details, which is where you say you want it!
Visits: 388
+xNo, the one in Flight Details, which is where you say you want it! Sorry, where?
(have to fix the Euro tag)
Visits: 32K
+x+xNo, the one in Flight Details, which is where you say you want it! Sorry, where?
(have to fix the Euro tag) You are right, it's gone.
Bizarrely, SD prompted me a day or two ago for a version update which I applied, but it seems that for whatever reason I was still running at 3.14.5.
I was not a fan of the old format, as it seemed a bit cramped, but I'm not sure I like this new format better. The specific date/time take-off time is a mess.
Visits: 388
+xYou are right, it's gone.
Thanks for conformation. Yes, I don't think the current PC version earns an award neither for prettiness nor for GUI. Maybe time for a small overhaul project for a student?
fluidflow
Visits: 31
Some time passed by but you can also find two small numbers at the right top corner, right below the cross to close.
Regards!
