Flight Duration in Skydemon Plan on PC ?
It is been a while since I used the PC version, but when reviewing my todays flight I realized the flight duration display is gone under Flight Details section, but now I have a 'costs' display, which I don't care. When did the flight duration disappear or is is hidden somewhere else?
*update* Ok, saw the same is now true for 'Flight Details' from the Route menu on the mobile device, maybe inherited. Question: I don't care for Endurance or Flight Cost when looking at Flight Details, I need at least Flight Duration there - any chance to get that?
Edited 12/29/2020 10:02:29 PM by pilot-byom
Posts: 631, Visits: 31K
pilot-byom - 12/29/2020 9:50:26 PM
On a mobile device, the total distance and duration are given right there in the centre at the top of the chart.
grahamb - 12/30/2020 12:00:11 AM
I know that, but also in the mobile version distance and duration are no longer where it is expected - in Flight Details.
*update* Ok, found it as a small label on the uttermost top right of the screen, not the best solution. Thread can be closed.
Edited 12/30/2020 10:19:36 AM by pilot-byom
pilot-byom - 12/30/2020 7:00:47 AM
On the PC version, it is given in brackets after the landing time in the 'Timings' section.
grahamb - 12/30/2020 11:07:13 AM
Which 'Timings' section do you refer to, the one visible only after generating a PLOG?
pilot-byom - 12/30/2020 12:00:48 PM
No, the one in Flight Details, which is where you say you want it!
grahamb - 12/30/2020 1:21:49 PM
Sorry, where?
(have to fix the Euro tag)
Edited 12/30/2020 2:11:23 PM by pilot-byom
pilot-byom - 12/30/2020 1:46:47 PM
Sorry, where?
You are right, it's gone.
Bizarrely, SD prompted me a day or two ago for a version update which I applied, but it seems that for whatever reason I was still running at 3.14.5.
I was not a fan of the old format, as it seemed a bit cramped, but I'm not sure I like this new format better. The specific date/time take-off time is a mess.
grahamb - 12/30/2020 4:04:26 PM
Thanks for conformation. Yes, I don't think the current PC version earns an award neither for prettiness nor for GUI. Maybe time for a small overhaul project for a student?
Edited 12/31/2020 9:09:52 AM by pilot-byom
fluidflow
f
Forum Member (41 reputation)Forum Member (41 reputation)Forum Member (41 reputation)Forum Member (41 reputation)Forum Member (41 reputation)Forum Member (41 reputation)Forum Member (41 reputation)Forum Member (41 reputation)Forum Member (41 reputation)
Posts: 3, Visits: 31
Some time passed by but you can also find two small numbers at the right top corner, right below the cross to close.
Regards!
