Update W&B data & fuel on multi stop plan
FlorianK
F
Too Much Forum (438 reputation)Too Much Forum (438 reputation)Too Much Forum (438 reputation)Too Much Forum (438 reputation)Too Much Forum (438 reputation)Too Much Forum (438 reputation)Too Much Forum (438 reputation)Too Much Forum (438 reputation)Too Much Forum (438 reputation)
Posts: 9, Visits: 18
when planing a trip with a stop by using the “land here” functionality in the planning mode, fuel and weights for the second flight are reset to the default values of the plane. I would be very helpful if the passenger & cargo weights would be transferred from the first flight (as most of the times we continue flight with the same load). Also it would be helpful if the fuel would be set to the expected fuel at that stop (fuel of previous flight minus the minimum fuel for previous flight except reserves). Of course we need to check fuel levels before the second flight and enter the correct value before we start, and yes, but when planning a trip to an airfield where no fuel is available it would be very helpful if we could directly see whether or not we can expect to have enough fuel for the return flight. And when entering the expected takeoff time, the default shouldn’t be now but instead the calculated landing time of the first flight.
Best regards
Florian
I believe this is not a good idea. Yes, it may be a convenience thing, but it tricklulls pilots into relying on a sole simulation of flight. I prefer to treat each leg on its own with separate flight planning - i.e adding a personal motivated additional fuel quantity for uncertainty of stops. How could you include this without attracting the feature creep?
Posts: 615, Visits: 30K
pilot-byom - 10/3/2020 10:39:41 AM
I agree.
Even when I plan a multi-leg trip as one big route with 'land-heres' included (which I generally don't do, but can be useful in helping to see the bigger picture on a really long trip), I treat each leg as its own flight and want to enter my estimated times and fuel requirements manually.
I don't want unecessary complexity introduced into the product for the sake of having something that tries to model uncertainty too closely.
Edited 10/3/2020 12:23:36 PM by grahamb
