GS quirk on first leg when manually setting all legs wind
sjhoare77
s
Posts: 2, Visits: 0
Planning a route today on my Android tablet using the latest version of SkyDemon and I noticed the following oddity. I was overriding the auto winds, as I was practising using my whizz wheel, so had set an all legs wind of 300/10. However on the first leg with a track of 324 deg my PLOG (attached) shows a ground speed of 90 kts; whereas the minimum it could be fighting a straight on headwind would be 100 kts. Has anyone seen this before or can indicate where I've screwed up?
PrintItem.pdf (514 views, 42.00 KB)
sjhoare77
s
Posts: 2, Visits: 0
Tim Dawson - 6/12/2020 8:35:31 AM
You haven't screwed anything up (probably), it's just difficult to compare SkyDemon's flight modelling results with that of a whizz wheel. What you're seeing is because you're spending a proportion of that first leg in a climb, and that portion will have a lower groundspeed, so that is bringing the leg average down.
Thanks Tim - much appreciate your input on that. I really did think I was going slowly mad in lockdown. Just out of curiosity, is there a way of displaying the climb speed or the average leg speed on the Plog?
