Charts and Aeronautical Data
Skydemon Windows 3.13.3.0: Mapping - Routes - Helicoper Routes
BearLS
BearLS
posted 2/24/2020 7:10:34 PM
Visits: 226
What is the effect of marking/unmarking Mapping - Routes -
Helicoper Routes
At LSGS the
waypoints
for helicopters are switched on/off but
not
the routes.
Is that the intended use? If not, you might re-think the wording "Helicoper Routes". Thank you.
Bear
NB
I would prefere an effect on waypoints
and
on routes.
posted 2/25/2020 10:07:40 AM
Posts: 8.3K,
Visits: 9.9K
The setting is for enroute routes, not local arrival/departure lanes.
BearLS
BearLS
posted 2/25/2020 7:23:02 PM
Visits: 226
The setings do not have an influence on enroute routes:
Mapping - Routes - Helicoper Routes ON
Mapping - Routes - Helicoper Routes OFF
The HEL REP HE, HN amd HS are switched on/off. The local helicopter routes to no-name positions. Does that make sense?
I might be the only user but I propose that the flag influences
1 helicopter routes
2 local helicopter roues
3 helicopter reporting points
posted 2/27/2020 11:59:43 AM
Posts: 8.3K,
Visits: 9.9K
Everything in your screenshot is an aerodrome arrival/departure route. They are not enroute helicopter routes, so they are unaffected by the mapping switch for helicopter routes.
The main mapping switch is there so that people who don't fly helicopters do not see helicopter routes that they have no use for. It would be unsafe for that switch to also turn off aerodrome helicopter routes because you definitely need to know the routes other traffic can and will be using to approach the same aerodrome as you are.
