What happened to the airspace design?!
Johannes B.
J
Too Much Forum (738 reputation)Too Much Forum (738 reputation)Too Much Forum (738 reputation)Too Much Forum (738 reputation)Too Much Forum (738 reputation)Too Much Forum (738 reputation)Too Much Forum (738 reputation)Too Much Forum (738 reputation)Too Much Forum (738 reputation)
Posts: 53, Visits: 1
Since the update today the restricted airspaces as well as the notams are covered with horrible lines, which makes everything look extremely cluttered! Please get rid of this feature asap, I can't turn it off...
YouTube channel
Edited 11/5/2019 7:12:59 PM by Johannes B.
Johannes B.
J
Johannes B. - 11/5/2019 7:06:19 PM
Anybody else with this problem? Seems to be an Android only mishap, the airspace graphics of a friends ipad 5 looks almost as usual. I am using a Huawei Mediapad 3 and a S10.
YouTube channel
Edited 11/5/2019 8:55:58 PM by Johannes B.
SkyDemon Team (707K reputation)SkyDemon Team (707K reputation)SkyDemon Team (707K reputation)SkyDemon Team (707K reputation)SkyDemon Team (707K reputation)SkyDemon Team (707K reputation)SkyDemon Team (707K reputation)SkyDemon Team (707K reputation)SkyDemon Team (707K reputation)
That's how they're supposed to look, with the cross-hatching, if that's what you are referring to.
Johannes B.
J
Until yesterday there was never any cross hatching visible, and neither is this visible on the iPad version. Please send me pictures of the same locations and similar zoom factor, I am confident this is unusual. Please compare the pictures I posted above to the one below...
YouTube channel
Edited 11/6/2019 3:39:43 PM by Johannes B.
I can see cross-hatching in that screenshot. Try on the PC too.
Johannes B.
J
Tim Dawson - 11/6/2019 4:11:36 PM
I can see it too, but it is far less obvious and distracting, will try the pc...
YouTube channel
Johannes B.
J
I have sent several comparable screenshots to you which show the different appearance between android after the 12.13 update and iOS. They look totally different, I will post some more examples later. To all Android users out there, please check the airspace depiction (restricted & notam areas) and post some response here.
Edit: unable to upload more screenshots somehow, but I have sent them to the support team.
YouTube channel
Edited 11/7/2019 7:30:57 PM by Johannes B.
Posts: 385, Visits: 2.6K
Johannes B. - 11/7/2019 4:51:25 PM
Class D airspace depiction (in UK) looks okay to me (on Android). I am using SkyDemon 2 map style.
Tony
Johannes B.
J
tnowak - 11/8/2019 8:50:26 AM
Tony
I am speaking about restricted areas and notams, class d looks normal for me as well. The map style does not effect the pattern of the airspace boundaries.
YouTube channel
Edited 11/8/2019 4:31:55 PM by Johannes B.
As far as I can tell, this is by design. NOTAMs, restricted and danger area are supposed to have a hatched inner fill around their borders. Recently a bug was fixed where we failed to increase the size of the hatching on high density screens so it looked like a solid fill. That fix is in the current Android version and will be in the next iOS version too.
SkyDemon Plan is largely unaffected by this as high-density screens are rarer on PC.
