SkyDemon V2.1.1
Runways
Runways
Posts: 309, Visits: 1.6K
I considered myself lucky today. First I met one of the ardent supporters of SD face to face and briefly discussed SD compatible hardware. That was excellent and hope to repeat the experience without having to rudely rush away, as I did today due to time constraints.
However, the reason for writing here is to report my experience with the latest SD version 2.1.1, which I managed to put to the test in a flight, in marginal and IFR weather conditions. As we all expected SD passed with flying colours. here is my summary:
1. The colour moving map appeared enhanced, very clear to see and totally uncluttered.Ideal.
2. The options that we needed the most we found very easily acceptable, merely within a 2-4 touches of the screen. Changing from map to instrument was simply ideal. Go to nearest or more distant field was very simple and the selection list was intuitive.
3. The instrument screen we found virtually breathtaking, with its simplicity usability, clarity and above all accuracy.
4. Localiser, glideslope, and DME were very accurate and could easily have replaced our aircraft's own instruments. We would have liked to have tested these down to virtual ground level. I feel it would have shown it to be very reliable.
5. The colours of the instruments were well chosen and very clear. The ILS lines could be made thicker in future releases for better visibility inflight, particularly that screens in commonly used devices leave a lot to be desired.
6. My companion who is a seasoned flyer who survived two serious aeroplane accidents while doing low level aerobatics was extremely impressed with SD's accuracy.
Verdict: Full marks for SkyDemon and SkyDemon Team on a job well done. In my mind SD is by far the best software on the market. It has certainly come a long way since I subscribed first some 8 months ago. I am glad I did.
I would be interested to hear views from others.
Very Newbytheway
DurhamTeaseAirport
Runways
Runways
I totally agree. Having said that the crashes (there were only two) occurred at the interface between the two maps. Once the set was restarted the second time everything ran smoothly from then. I dare say that the required map redrawing at 450Kts may have been another factor that exceeded the set capability at the interface. Again, you are right in the fact that the colour moving map was left on with all the bells and whistles (roads, terrain etc) showing, as usual. As expected there were frequent alarms about entering and exiting airways as well as wind-mill farms at the final approach stages. So it all worked very well indeed.
Very Newbytheway
DurhamTeaseAirport
Runways - 5/7/2011 9:29:41 PM
     Thanks!
Tim Dawson - 5/9/2011 3:21:19 PM
screetch82 - 5/10/2011 9:11:36 AM
Runways - 5/10/2011 4:40:57 PM
Runways - 5/14/2011 12:47:44 PM
Runways - 5/17/2011 7:08:55 PM
stevelup - 5/18/2011 1:40:07 PM
Runways - 5/18/2011 3:01:06 PM
stevelup - 5/18/2011 3:37:27 PM
Runways - 5/18/2011 4:08:09 PM
Runways - 5/20/2011 12:23:40 AM
Bathman - 5/20/2011 3:37:31 PM
Tim Dawson - 5/20/2011 4:21:32 PM
Runways - 5/21/2011 12:03:53 AM
srayne - 5/21/2011 9:20:16 AM
Runways - 5/21/2011 10:35:26 AM
stevelup - 5/22/2011 6:47:17 PM
Runways - 5/22/2011 10:47:49 AM
Runways - 5/22/2011 9:14:47 PM
geejay - 5/23/2011 4:48:23 PM
Runways - 5/23/2011 7:41:01 PM
stevelup - 5/23/2011 7:57:10 PM
Runways - 5/23/2011 8:33:12 PM
geejay - 5/24/2011 7:31:13 PM
adhawkins - 5/24/2011 11:34:06 AM
Runways - 5/24/2011 11:54:11 AM
stevelup - 5/24/2011 2:45:50 PM
Runways - 5/24/2011 3:47:42 PM
stevelup - 5/24/2011 10:26:54 PM
adhawkins - 5/25/2011 11:48:53 AM
Runways - 5/25/2011 12:11:47 PM
Runways - 5/27/2011 12:41:43 PM
stevelup - 5/27/2011 2:48:46 PM
Runways - 5/27/2011 3:24:22 PM
stevelup - 5/28/2011 2:49:35 PM
Runways - 5/28/2011 4:46:41 PM
stevelup - 5/28/2011 6:31:30 PM
Runways - 5/29/2011 11:32:31 AM
