NO GPS INPUT FROM ANDROID DEVICE
OllieD
O
Too Much Forum (422 reputation)Too Much Forum (422 reputation)Too Much Forum (422 reputation)Too Much Forum (422 reputation)Too Much Forum (422 reputation)Too Much Forum (422 reputation)Too Much Forum (422 reputation)Too Much Forum (422 reputation)Too Much Forum (422 reputation)
Posts: 3, Visits: 0
Hi. I've just bought a Samsung Galaxy Tab S2, running Android 6.0.1 and added SD. I'm not getting any location data input into SD from the device - its constantly waiting for location data, although both GPS and WiFi location are enabled. I know this isn't a new issue, but couldn't find anything on here which helped resolve this. Is this still a known bug? Any fixes out there? Or alternatively, what devices are guaranteed to work smoothly with SD?
DirDej
DirDej
Posts: 120, Visits: 1.5K
You may have to allow Skydemon to use location data first.
OllieD
O
Posts: 3, Visits: 0
DirDej - 12/28/2016 1:53:57 PM
It is set to allow this, but still not taking the GPS feed from the tablet. I'm at a loss.
Posts: 378, Visits: 2.6K
Does your device work with any other application which needs to use the Tab S2's GPS?
Tony‌
OllieD
O
Posts: 3, Visits: 0
tnowak - 12/29/2016 9:23:24 AM
Tony‌
Thanks. It works OK with Google maps. It seems to be an incompatibility between the Android OS and SD. I've seen other threads on this, but no solution. Bizarrely, SD works fine on my Samsung phone.
OllieD - 12/29/2016 11:32:26 AM
Tony‌
...It seems to be an incompatibility between the Android OS and SD...
I‌ have had no problems with SD on my Nexus‌, running Android 6.0.1, so it could be a problem which is specific to the Tab 2.
‌‌I wonder if there are any other users experiencing problems with this particular combination?
26200.7840, SD 4.2.3
Benneman
B
Posts: 2, Visits: 0
Hi, just want to revive this thread as my problems are very similar. I just bought a Huawei M5 8" tablet specifically for skydemon and the location service doesn't seem to work. Either by pressing the location button or Go Flying the error message is:  Your location cannot be obtained.
The location does work in google maps.
- Yes SD has acces to location
- The tablet has LTE or a sim card but that should not be necessary
- Location works fine on Samsung S8 phone
- software versions: Android 9 Pie, Build number: 9.0.1.190, -SD version: 3.12.7
If OllieD is still around I wonder how he resolved the issue.
Ben
Benneman - 7/10/2019 9:36:24 AM
Ben
Can you confirm that your Huawei tablet is the LTE version. If so, turning on Location Services should automatically turn on GPS. Whether or not you have a SIM card inserted is irrelevant. If it is NOT an LTE version, then it has no internal GPS and an external GPS source will be required. Google maps will still work on a non-LTE device, because it will use WiFi to establish location. Hope this helps.
Benneman
B
Posts: 2, Visits: 0
Ok, so I took the tablet to another location outside and it works now. I think here inside my apartment the GPS reception is poor. Even when it is at the top apartment at the eight floor. Just taking it out to the balcony did the trick...
Benneman - 7/10/2019 1:03:10 PM
