Notes on rutes
Posts: 615, Visits: 30K
You can upload user documents to SD; if you prefix the document name with a four character ICAO ID, it will be placed with the documents for that airfield.
efrenken
efrenken
Posts: 265, Visits: 3.5K
These are examples for notes for an airfield (not route), which you already can add in the current version of SD.
You don‘t want to add notes like ‘AIRPORT BAR CLOSES AT 15:00 LT, PLAN EARLY ARRIVAL’ to xx routes which all end at the same airfield.
Eric
GADGET
GADGET
Posts: 1, Visits: 23
I wonder if it could be implemented a field to add personal notes to the routes we create and store with Skydemon.
For instance:
NICE RESTAURANT 5 MIN. FROM THE AIRPORT
ROOMS AVAILABLE AT THE AIRPORT
MOGAS FUEL AT 1,5 KM FROM AIRPORT
BUMPY RUNWAY, AVOID LEFT SIDE OF RWY 32
HELPFUL AIRCLUB EMPLOYEE NAMED NNNNNNNN
AIR PUMP U/S AT DESTINATION, DOUBLE CHECK TIRES BEFORE DEPARTURE
FARDEST ALTERNATE USED FOR PLANNING, CHECK BEFORE XXXX, YYYY AND ZZZZ ON THIS ORDER.
CALL 999999999 FOR FUEL ASSITANCE WHEN NOBODY AVAILABLE ON RAMP
This sort of things for particular use before/during/after flying.
Thx
