Extended runway centreline
stuartforrest
stuartforrest
posted 4/17/2011 10:40:55 PM
HOT
Visits: 108
I have previously posted that I couldnt understand how the giant runway centreline worked and asked if you could set it for the runway you were using. I was told it was automatic. I have to say that having flown into a few airfields today I really think that is a mistake!
Now every post on here I say how great SkyDemon is and I am a huge fan but as an ex PocketFMS user I have to say that was better in this area in that you could select the runway that you were going to fly to and it would show extended lines to that runway no matter which way you are coming from.
Please can we have the feature so we can choose the runway. I really think the automatic thing is a big mistake. You nearly always know miles out which runway you are using so even if it was automatic to start with an option to set the correct runway would be great.
Please?
G-FOZZ
www.gotoair.com
stuartforrest
stuartforrest
posted 4/28/2011 8:52:23 PM
Visits: 108
Is there no further comment on this one. Should I stop banging on about it. I can't see how a manual override would in any way spoil the current automatic function. It would just add a bit more flexibility to runways were they are close together such as 28 and 31 at Blackpool. For most of the approach to the airfield it is showing an extended centreline to 31 when I know I will be going to 28. Being able to say I know I am actually going to 28 would helpy you line up immensely and I agree with the previous comment about mile markers too. That would be lovely.
I promise I won't post any more comments on this but I really think it would be a very good improvement for the airfields with 6 or 8 runways.
G-FOZZ
www.gotoair.com
stuartforrest
Sounds good to me!
Baron von Mildred
4/18/2011 7:36:38 PM
Sounds good to me!
Baron von Mildred
4/18/2011 7:36:39 PM
Sounds a great idea to me. Any update from the team on this one....
stuartforrest
4/18/2011 10:16:34 PM
Seeing that we are visiting the extended centre line, could we have it...
Runways
4/19/2011 10:05:38 AM
For us to consider changing the way this works, a clear case would...
4/19/2011 3:08:08 PM
Aside from my point I raised above I feel neutral about the choice of...
Runways
4/19/2011 3:35:04 PM
I have to disagree. Properly implemented which of course it would be...
stuartforrest
4/19/2011 11:17:08 PM
Actually that's probably a better solution than my manual suggestion....
stuartforrest
4/19/2011 11:18:25 PM
Is there no further comment on this one. Should I stop banging on...
stuartforrest
I agree that the manual optionis an excellent suggestion
nje
4/29/2011 11:46:30 AM
I have to totally agree on manual selection as well. Helps with...
Tony
4/29/2011 1:25:31 PM
I agree with having automatic selection as default, with the...
Richard Avery
4/30/2011 12:10:19 PM
i think the best method should be similar to the garmin 296 system...
grobastir
4/30/2011 3:50:00 PM
i am new to skydemon and i have to say that i wish the extended runway...
grobastir
4/30/2011 4:03:45 PM
Would anyone care to share a screenshot of how the 296 depicts all...
5/2/2011 4:25:48 PM
Here are two pictures. Caernarfon and Blackpool. Please ignore the...
stuartforrest
5/9/2011 11:15:00 PM
and the second
stuartforrest
5/9/2011 11:15:27 PM
