Airspace around DKB (Germany)
SLaier
S
Posts: 2, Visits: 2
while familiarizing myself with skydemon, I came across an airspace that I could not match.
Maybe someone can help and see what the red airspace inside of airspace E is in the environment of DKB VOR (Germany) is. I can not find anything suitable in neither the chart nor the notams.
I would appreciate if someone could look into this.
Thanks!
SLaier
S
Posts: 2, Visits: 2
You are right. If you activate the "night-only Airspace", the corresponding airspace (LANTA Ansbach / EDR163A and B) is also visible in the chart
Thank you very much for your help.
