georeferenced charts keep appearing
Ralf Rösch
R
Posts: 5, Visits: 0
In Air Nav Pro, there is a setting-screen to chose between
- manually
- all airports on planned route
- departure/arrival airport on route
- nearest airport at current position
which I found a very convenient solution
br
Ralf
Ralf Rösch
R
Posts: 5, Visits: 0
...and to make it pefect (in my humble opinion) , in cases 2 and 3 SD will check if the plates are available and will otherwise download them automatically👌
Martin Bech
Martin Bech
Posts: 152, Visits: 352
Can anyone tell me what special information I should look for on the georeferenced plate?
I have always just tapped the red x and therefore maybe have missed the idea with georeferenced plates.
Paul Buckley
P
Posts: 34, Visits: 28
Martin Bech - 8/11/2018 12:39:27 PM
Can anyone tell me what special information I should look for on the georeferenced plate?I have always just tapped the red x and therefore maybe have missed the idea with georeferenced plates.
Hi Martin, georeferenced means SD shows your actual location on the chart in flight. rgds. Paul
Russ_H
Russ_H
Posts: 32, Visits: 70
Just want to add my vote for some way (switch?) to surpress or enable the aip chart overlay, I find I mostly dont want it except when planning
I can confirm there is now an option to prevent the automatic display of georeferenced plates, as of the forthcoming version.
