GAR reverses my route
112Rockwell
1
Too Much Forum (129 reputation)Too Much Forum (129 reputation)Too Much Forum (129 reputation)Too Much Forum (129 reputation)Too Much Forum (129 reputation)Too Much Forum (129 reputation)Too Much Forum (129 reputation)Too Much Forum (129 reputation)Too Much Forum (129 reputation)
Posts: 2, Visits: 0
When I have a flight and route planned from the UK to France the GAR section always reverses this and says the route is France to the UK. Which it is not.
This suggest that to me that it is not possible to submit a GAR from the UK to France. Am I correct.‌?
T‌he route shown on my SD is from a UK airfield to a recognised Immigration entry point in France.‌
A‌ny suggestions as to what is going on.‌
Guy
G
Too Much Forum (281 reputation)Too Much Forum (281 reputation)Too Much Forum (281 reputation)Too Much Forum (281 reputation)Too Much Forum (281 reputation)Too Much Forum (281 reputation)Too Much Forum (281 reputation)Too Much Forum (281 reputation)Too Much Forum (281 reputation)
Posts: 4, Visits: 0
For UK to France/Belgium is no GAR needed
112Rockwell
1
Posts: 2, Visits: 0
Guy - 6/25/2018 8:28:32 PM
OK.
I‌ see what you mean. You have to contact the airfield directly rather than send a GAR.‌
Guy
G
Posts: 4, Visits: 0
You have to send an immigration report
Guy
G
Posts: 4, Visits: 0
For example see website Calais
Posts: 343, Visits: 2.5K
GAR is a UK requirement for INBOUND flights to UK only. No need (or requirement) to submit for OUTBOUND flights.
A‌s the previous poster said, you need to use/follow your French destinanation's inbound notification requirements.
J‌ust in case you aren't familiar with where to get the info, take a look at the French SIA website and look at the relevant VAC atlas charts/info:
https://www.sia.aviation-civile.gouv.fr/
T‌ony‌
Posts: 8.1K, Visits: 9.2K
112Rockwell, SkyDemon is not reversing your route. If you read what SkyDemon is saying carefully, you'll see that because you've planned an outbound flight to France, SkyDemon is offering you the opportunity to file a GAR for your return flight.
A‌‌ GAR is not required for a flight outbound from the UK to France, as others have pointed out.
