VFR Routes Copenhagen
Martin Bech
Martin Bech
Too Much Forum (9.8K reputation)Too Much Forum (9.8K reputation)Too Much Forum (9.8K reputation)Too Much Forum (9.8K reputation)Too Much Forum (9.8K reputation)Too Much Forum (9.8K reputation)Too Much Forum (9.8K reputation)Too Much Forum (9.8K reputation)Too Much Forum (9.8K reputation)
Posts: 148, Visits: 351
When flying a VFR flight to EKCH, I need the VFR routes(1,2,3 and 4) shown on the map since approach and CTR direct me along 1 or more of these routes. The routes are shown on ICAO map for Copenhagen. I have activated VFR routes in Map Layers. Regards, Martin
SkyDemon Team (623K reputation)SkyDemon Team (623K reputation)SkyDemon Team (623K reputation)SkyDemon Team (623K reputation)SkyDemon Team (623K reputation)SkyDemon Team (623K reputation)SkyDemon Team (623K reputation)SkyDemon Team (623K reputation)SkyDemon Team (623K reputation)
Posts: 7.8K, Visits: 8.4K
I will ask my colleague if this data is readily available to us.
I can confirm we'll be including these routes in Thursday's chart amendment.
Martin Bech
Martin Bech
Thanks Tim for this rapid response. SkyDemon is the best!
Regards Martin
Martin Bech
Martin Bech
Hi Tim
The VFR routes around EKCH is gone again?
That's strange, I will approach my colleague for input again. Thanks.
We have the VFR routes as per the current visual approach chart. Please check you are not comparing with an out of date chart.
Martin Bech
Martin Bech
The ICAO chart for Copenhagen area is showing VFR routes 1, 2, 3 and 4. The chart is from april 2017. I phoned EKCH and they informed me that these routes no longer exist (had to talk to 3 different guys before result). There is now only one VFR route close to EKCH, called Ellehammer. Skydemon is showing Ellehammer and therefore correct. Thanks for your help! Will inform my flightclub about the new status around EKCH.
