Posts: 8.2K,
Visits: 9.7K
How have you set up your private strip?
You may wish to create it as an actual airfield within SkyDemon, using the Data Creator tool on a PC. That way, SkyDemon will recognise it as an aerodrome for the purposes of logging your takeoff and landing. If it's close to a well-defined aerodrome but only defined itself as a user waypoint (I assume this is how you have it working at the moment) then SkyDemon may pick the aerodrome instead.
