How can I disable decluttering or hiding airspace above 4000ft
Yuzzi
Y
Too Much Forum (543 reputation)Too Much Forum (543 reputation)Too Much Forum (543 reputation)Too Much Forum (543 reputation)Too Much Forum (543 reputation)Too Much Forum (543 reputation)Too Much Forum (543 reputation)Too Much Forum (543 reputation)Too Much Forum (543 reputation)
Posts: 5, Visits: 0
Hi, I want to know how I can turn off the feature decluttering or where can I change the hiding airspace 4000ft feature "inflight" on my iPad? E.g. I want to see all the airspace from EDDP but it hides the beginning airspace at 5500ft.
Yuzzi - 4/25/2017 10:07:06 PM
Page 11 of the SD Manual
6575, SD 4.2.2
Yuzzi
Y
Posts: 5, Visits: 0
Hi Mike, I have read the page you recommended, but I haven't found a solution for my Problem.
Is there a step by step guideance to bring me to the menu point?
I tried a lot of settings with the setup and the blue Map Layer button >> automatic decluttering >> when flying BUT i always get the message "hiding airspace above 4000ft"
Are you actually flying when you see that message?
Yuzzi
Y
Posts: 5, Visits: 0
Yes and No ... I try it in X-Plane ... and here I didn't see the airspace above 4000ft inflight.
Will not try it in the real Plane! Here I have other things to do 😜
Yuzzi
Y
Posts: 5, Visits: 0
O.k. I think there is no solution for my problem 😞
I think there probably is, but you need to articulate the problem more clearly including exactly what you have tried, and what happened. You can always call our customer support too.
