AFE plates for FEARN and EASTER airfields on PC version 3.7.1.0
manix
manix
Too Much Forum (325 reputation)Too Much Forum (325 reputation)Too Much Forum (325 reputation)Too Much Forum (325 reputation)Too Much Forum (325 reputation)Too Much Forum (325 reputation)Too Much Forum (325 reputation)Too Much Forum (325 reputation)Too Much Forum (325 reputation)
Posts: 5, Visits: 11
F‌earn airfield and Easter airfields are immediately adjacent ‌to each other. They both have AFE plates, but attempting to open the Fearn plate results in the Easter plate opening (opening the Easter plate results in the correct plate opening).
N‌either of them have an API and I don't have an on line Pooleys subscription so I've been unable to test those.‌
I‌ have also tested the IOS version of SkyDemon, with the same result.‌
manix
manix
Sky Painter - 2/9/2017 8:18:35 AM
manix - 2/8/2017 7:51:56 AM
I can confirm that Pooleys DO NOT have a plate for Fearn and their plate for Easter indicates that Fearn is disused. Consequently, if I press and hold on Fearn and tap on Information, the plate for Easter is loaded.
That's interesting. I'm basing my comment that Fearn has an AFE plate on the fact that (on a PC) when you click 'Find plates' on Fearn and Easter, then SkyDemon displays a list of plates for both Fearn and Easter. As stated earlier, it doesn't matter which of the two airfields you choose, you get the Easter plate.My printed AFE is in the aircraft, so not immediately available for me to check.
