SkyDemon Flight Planning
Odd behaviour printing route chart
T67M
T67M
posted 8/20/2016 4:25:09 PM
Visits: 3.2K
I just printed a route chart out for a flight tomorrow, and I notice that the useful boxes giving heading, time and distance on each leg have been replaced by the slightly less useful text "tap to unlock". I have tried tapping the paper, but nothing happened! ;-)
posted 8/21/2016 7:12:18 AM
Visits: 15K
x
T67M - 8/20/2016 4:25:09 PM
Perhaps you're printing on the 'wrong' type of paper. Lol.
Samsung Galaxy Tab A8 – Android 11.0 & SD
4.1.2
6396, SD 4.1.2
tijssel
tijssel
posted 8/21/2016 12:21:10 PM
Visits: 307
The information on heading and time is based upon the selected aircraft and weather information.
So the question is; was the aircraft selected and was the weather information available and loaded.
For this reason it isn't very useful to print this one day before --if you want to use this information-- as you will not have accurate weather and wind available one day before your flight.
Regards, Tom
T67M
T67M
posted 8/21/2016 7:25:35 PM
Visits: 3.2K
x
tijssel - 8/21/2016 12:21:10 PM
The information on heading and time is based upon the selected aircraft and weather information.So the question is; was the aircraft selected and was the weather information available and loaded.For this reason it isn't very useful to print this one day before --if you want to use this information-- as you will not have accurate weather and wind available one day before your flight.Regards, Tom
Good thoughts, tijssel, but in this case I had an aircraft selected and the time was sensible and when weather forecasts were available. I have just re-tried the print with today's date/time and I still get the "tap to unlock" message.
Just in case it makes a difference, this is all in SD 3.6.3.0 running on Windows 10 64-bit v1511 build 10586.545 on an Intel Core i5 machine.
morane
m
morane
posted 8/23/2016 7:52:11 AM
m
Visits: 0
x
morane
m
morane
posted 8/23/2016 7:54:43 AM
m
Visits: 0
x
I do see the same problem, using windows10, Hans
George Reid
George Reid
posted 8/23/2016 8:57:44 AM
Visits: 1.6K
x
Shifu - 8/23/2016 8:19:55 AM
Tried printing after reading this thread and my Skydemon Plan Win10 does not print at all, error message: "Could not print because of an internal error".
*update* Upon checking the print system of Windows10 I found three "dead" printer entries - no idea where they came from, but after deletion I could reproduce the "tap" error. But, after I restarted the print system I does print now correctly. Looks like there is/was a problem in Windows10, at least here.
I too have the same "tap error" problem with my Win 10 PC
George E A Reid
Ipad Mini 5, IOS 14.4, SD 3.15.0.288
PC(Win 10, Version 19041.804) SD 3.15.0.0
posted 8/24/2016 11:56:46 AM
Posts: 8.2K,
Visits: 9.7K
This is, obviously, a bug. It's fixed in the forthcoming version. Thanks all for pointing it out.
