GPS
Martin Bech
Martin Bech
Posts: 152, Visits: 352
Hi
If I buy a Garmin GLO gps, with GPS and GLONASS, can that be used by SkyDemon on Ipad for a more precise position than from the internal GPS in Ipad?
/Martin
Edited 3/14/2016 11:56:00 AM by Martin Bech
Yes
Martin Bech
Martin Bech
Thanks Tim - always good service!
/Martin
Martin Bech
Martin Bech
How can I see that SkyDemon uses Garmin GLO instead of Ipad internal GPS? Furthermore do anyone know if the Ipad also uses Glonass and then should be as precise as Garmin GLO?
/Martin
Edited 3/17/2016 9:06:26 AM by Martin Bech
iOS does not tell you (or apps) explicitly that it is using your external GPS receiver. You just have to trust it, unfortunately.
Martin Bech
Martin Bech
http://forums.skydemon.aero/uploads/images/c74a390a-4f50-429c-ae71-05ed.pngI have installed Garmin Pilot for trial and that shows me GLO is connected and even the battery status. I did not have to configure anything for that to work.
Would it be possible for SkyDemon to show that it is using the GLO, but not necessarily the battery status?
Nope. The only reason the Garmin app can show you that is that it has a proprietary link with the Garmin GLO, which is not available to other apps (sadly).
makmak
makmak
Too Much Forum (823 reputation)Too Much Forum (823 reputation)Too Much Forum (823 reputation)Too Much Forum (823 reputation)Too Much Forum (823 reputation)Too Much Forum (823 reputation)Too Much Forum (823 reputation)Too Much Forum (823 reputation)Too Much Forum (823 reputation)
Posts: 5, Visits: 90
I use an ipad mini which does not have a built-in gps together with a garmin glo. If I turn off wifi (which is also used for positioning) and I still have a position, it must be because the glo is connected Smile
Mike Stueber
Mike Stueber
Posts: 54, Visits: 193
Go to settings(Einstellungen), privacy(Datenschutz) and then to location services(Ortungsdienste). If you switch the location services off, the internal GPS is also switched off.
...and also your external GPS.
