SkyDemon Navigation
Night Flying
Night Flying
Night Flying
hucbr600
hucbr600
posted 12/9/2015 5:28:05 PM
Visits: 240
Hi Folks,
Has anyone tried the various charts/ipad mini setting to determine what combination works best during night flying?
If so - fancy sharing your preferred set-up?
Hugh
kobaje
kobaje
posted 1/2/2016 12:33:25 PM
Visits: 205
Hi Hugh,
my preferred setting is "Sky Demon High Contrast Map" with brightness set to minimum. Although it should be a little darker, it works quite well.
Cheers
Jens
Night Flying
hucbr600
Hi Hugh, my preferred setting is "Sky Demon High Contrast Map" with...
kobaje
Great Tip Tim about the reduce white point option. Thanks I have...
olivier_RD
11/9/2022 7:33:11 AM
Have you not tried the ‘SkyDemon High Contrast’ chart style, found...
11/9/2022 9:12:30 AM
@kobaje, if you are flying on NVIS your problem is more likely to be...
DaveWhite
11/9/2022 11:53:39 PM
