Posts: 8.3K,
Visits: 9.9K
SkyDemon selects the leg which you are closest to, as the "current" leg. I believe there is also some directional logic to this, too.
We do not plan to make the login more complicated; it used to be, many years ago, but this resulted in too many problems due to nuances in certain routes. If you're in the rare situation where SkyDemon isn't selecting the "appropriate" leg when there are more than one identical legs, you may need to divide your route into different sectors (or even different files) and select the current sector manually.
