Wrong plate for EHST (stadskanaal)
Bouwair
Bouwair
Posts: 41, Visits: 2.9K
We now get the wrong approach plate for EHST. The plate we get now is for EHSE. It used to be OK but when I updated the AIP for the Netherlands last week this has changed. Can you please have a look at it?
With kind regards,
Freerk
Tags
The plate for EHST looks ok to me. Can anyone else reproduce this? I see the Woensdrecht CTR seamlessly between the plate and our charts when I display it.
w5400
w5400
Posts: 18, Visits: 102
Tim
just replicated this issue on PC Version 3.4.1.0. AND Ipad 3.4.1.15.
In both cases entering EHST (Stadskanaal) in FIND PLATES brings up the approach charts for EHSE (Seppe/Hoeven). Textual information is not affected by this glitch.
Cheers
Victor
Very strange. This is what I get when I try. Am I missing a step?
tijssel
tijssel
Posts: 21, Visits: 307
Tiim, that's correct only this plate belongs to a different airfield. When you ask the plates EHST or EHSE you get the same plate but the fields are a few hundred kilometers away from each other.
Regards, Tom
w5400
w5400
Tim
you are getting the wrong plate as well. This is what you should be getting for EHST
http://forums.skydemon.aero/uploads/images/6ce3103f-f80c-4106-8f95-6394.jpg
http://forums.skydemon.aero/uploads/images/16056a95-cd23-4cd6-bbdb-d9da.jpg
Instead you are getting this airfield
http://forums.skydemon.aero/uploads/images/3ca0b0f9-c40a-4477-b0e6-6176.jpg
which is EHSE, Hoeven/Seppe, near Breda
http://forums.skydemon.aero/uploads/images/3c9d5150-a172-4b94-8903-29e9.jpg
Ah, I get it, thanks for bearing with me. I think what's happened is that the plate was published originally with a typo in its filename which meant it got assigned to the wrong airfield. Having looked at our data I suspect this will correct itself overnight tonight, with the new AIRAC cycle. Let's check again tomorrow morning to ensure it has fixed itself.
w5400
w5400
It has :-)
Bouwair
Bouwair
Thanks a lot
