W+B issue
SimonM
SimonM
Too Much Forum (644 reputation)Too Much Forum (644 reputation)Too Much Forum (644 reputation)Too Much Forum (644 reputation)Too Much Forum (644 reputation)Too Much Forum (644 reputation)Too Much Forum (644 reputation)Too Much Forum (644 reputation)Too Much Forum (644 reputation)
Posts: 12, Visits: 63
So... I have set up my aircraft with an empty weight of 1518.1 lbs and a CoG(Lon) of 38.56, added all the corresponding info into the aircraft configs like so...
35.00,1518.1  35.00,1950.0  39.50,2400.0  47.30,2400.0  47.30,1518.1  to create the polygraph.
Returning to the flight planning page and entering zero for all the weights why does it show an empty weight of 1505.4lbs and a CoG of 38.48?
Edit to say...This is the PC version WIn7
Edited 8/26/2015 6:48:49 PM by SimonM
SimonM
SimonM
Spot on, thanks Pete.
As you quite rightly say, It seems that Skydemon takes into account the taxi time (fuel used) and deducts this to calculate take-off weight.
I had the default 8.0 ltrs set for taxi time therefore approx 13lbs were removed from the empty weight of the aircraft which is then used for subsequent calculations.
If my taxi time is going to be short then I need to adjust the setting accordingly if operating at close to MAUW.
Pete
Pete
Posts: 129, Visits: 959
Yep, on a commercial aircraft load sheet (W&B) the fuel on board is reduced by the taxi fuel(which can be considerable with larger aircraft) so that take off wt is correct.
SD also does this, but the way it is implemented means that you get the result you found with zero fuel, put your taxi fuel into SD fuel window and you should get your empty wt that you entered.
regards
Pete
SimonM - 8/26/2015 6:25:58 PM
Pete - 8/26/2015 7:10:51 PM
SimonM - 8/26/2015 7:40:19 PM
Pete - 8/26/2015 10:14:00 PM
