W+B issue
http://forums.skydemon.aero/Topic16898.aspx
By SimonM - 8/26/2015 6:25:58 PM
So... I have set up my aircraft with an empty weight of 1518.1 lbs and a CoG(Lon) of 38.56, added all the corresponding info into the aircraft configs like so...
35.00,1518.1  35.00,1950.0  39.50,2400.0  47.30,2400.0  47.30,1518.1  to create the polygraph.
Returning to the flight planning page and entering zero for all the weights why does it show an empty weight of 1505.4lbs and a CoG of 38.48?
Edit to say...This is the PC version WIn7
By Pete - 8/26/2015 10:14:00 PM
Yep, on a commercial aircraft load sheet (W&B) the fuel on board is reduced by the taxi fuel(which can be considerable with larger aircraft) so that take off wt is correct.
SD also does this, but the way it is implemented means that you get the result you found with zero fuel, put your taxi fuel into SD fuel window and you should get your empty wt that you entered.
regards
Pete
